Old 06-07-2019, 12:05 PM   #1
Dodge Guy's Avatar
Tinting windows?
Hello. Has anyone tinted there front side windows? All my other windows are factory tinted. I had read years ago that you shouldnít tint thermal pane windows because the heat radiated back out can raise the pressure in between the 2 lanes and break the seal! All my cars have tinted windows and iíde like the TV to also. Just donít want to risk an expensive glass replacement.
Thanks!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 06-07-2019, 12:34 PM   #2
Try this:
https://www.forestriverforums.com/fo...ng-186546.html
TheWolfPaq82 is online now   Reply With Quote
Old 06-08-2019, 04:11 PM   #3
Dodge Guy's Avatar
Thanks Wolfpaq. But I didn’t see anything in their regarding tinting thermal pane windows and the potential issue I mentioned.
Old 06-08-2019, 04:30 PM   #4
llr
I have not heard of thermal pain issues. One option would be to apply the tint to the outside, not sure how long it will hold up but I suspect it would not be to hard to remove if needed
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is online now   Reply With Quote
Old 06-17-2019, 11:25 PM   #5
We bought our 2016 FR3 used and the fronts were tinted. I'm in the process of redoing them since I didn't like the quality of the job but they don't have any issues and they have been tinted for a while now.
wp1130_2000 is offline   Reply With Quote
Old 06-18-2019, 07:48 AM   #6
Dodge Guy's Avatar
Good to know everyone. I did verify from thermal pane manuf that they are not supposed to be tinted. However they also said they haven’t had anyone complaints of failures. It may be a CYA note so they have themselves covered. I may do it since the MH will be stored indoors.
Old 06-18-2019, 08:30 AM   #7
Originally Posted by Dodge Guy View Post
Good to know everyone. I did verify from thermal pane manuf that they are not supposed to be tinted. However they also said they havenít had anyone complaints of failures. It may be a CYA note so they have themselves covered. I may do it since the MH will be stored indoors.
The tint will have minimal effect. There are tons of residential windows out there with a low-e metallic coating on the inside of the interior lite reflecting outward with no problems. The RV window manufacturer should be more concerned about a sealed IG unit traveling from sea level to 11,000 feet. They do nothing to compensate for that.
woo10-210 is online now   Reply With Quote
Old 06-18-2019, 08:30 AM   #8
Yes I keep ours stored in our shop as well so no all day sun beating on the glass but there were previous owners so not sure how they kept it? A lot of people do it though. I'm up in Wisconsin and our climate isn't that harsh.
window
