View Poll Results: Are tire covers needed?
Yes 85 76.58%
No 26 23.42%
Voters: 111. You may not vote on this poll
Old 08-04-2016, 10:05 AM   #61
Jimandchris's Avatar
"tireman" had an interesting example in his blog regarding tire life and covers. Would like to know if there is data that backs his example but sounded like finite analysis.
www.rvtiresafety.com/search/label/tire%20life
2019 Coachmen Freedom Express 281RLDSLE
2018 2500 HD Silverado
Equal-i-zer Hitch E4
Jimandchris is offline   Reply With Quote
Old 08-05-2016, 06:20 AM   #62
Wolverine 1945's Avatar
For me it is tire Black & Covers,,, what do I have to loose,,, besides if the tires are not Black & shiny the RV - Car or Truck do not look clean to me !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-16-2016, 04:25 PM   #63
A school bus driver advised me to go to the bus garage and see if they had any older bus seat covers they didn't want. Got 4 for my tires for free. They had replaced the "damaged ones" from the busses with new ones. Not as nice looking as store bought ones but they do the job and at no cost.
rogerkathy is offline   Reply With Quote
Old 08-17-2016, 05:59 AM   #64
Price sounds right !!!
From one Roger to another !!!
Old 08-17-2016, 06:24 AM   #65
Herk7769's Avatar
303 Aerospace Protectant is the best (IMO) UV tire protection product on the market.
I use it on the car, truck, and camper tires. Since the truck and car get used all year, the protectant is all I use, but the campers tires only rotate when moving during trips so they get covers when not actually moving.
Tire movement rotates fresh internal rubber lubricants to the surface to keep the rubber supple. Ultraviolet light breaks down that surface lubricant making the tire surface dry out and crack when finally rotated.
Silicone spray may make a tire look good, but the UV rays go right through. You just get shiny cracked tires.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 08-21-2016, 04:01 PM   #66
Had tires covers and my michelins still dry rooted 16000 miles 2 years old?Click image for larger version
Name:	ImageUploadedByForest River Forums1471813274.897657.jpg
retired on a mountain is offline   Reply With Quote
Old 08-21-2016, 04:22 PM   #67
Well, they WERE made in Canada. Were they really 2 years old? Did you check the dates on the tires?
2011 Traverse LT, 3.6L, FWD
Old 08-21-2016, 04:26 PM   #68
[QUOTE=rockfordroo;1296215]Well, they WERE made in Canada.
I wouldn't slam the USA like that.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 08-21-2016, 04:28 PM   #69
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
X2
Grampa Jim is offline   Reply With Quote
Old 08-21-2016, 04:46 PM   #70
Herk7769's Avatar
Especially with ST tires, you MUST check the manufacture date on the sidewall BEFORE you have the tire shop mount them. They are normally stocked by most tire stores, but have an exremely low turnover rate.
Your "new" tires could be 2-3 YEARS old up in the hot loft before they get rolled down to be installed. They may look great, but the abuse and long storage will show up sooner or later.
The 4 numbers in the mold reflect the week and year of manufacture.
This Marathon ST radial was made in the 25th week of 2010 (2510)
Name:	Goodyear Marathon Made in USA 006.jpg
Old 08-21-2016, 05:01 PM   #71
Yes called Michelin
Old 08-21-2016, 05:12 PM   #72
[QUOTE=wana65stang;1296220]
Sorry, I was trying to be funny (a little poke at the China bomb people) , but my phone doesn't do emoticons.
Old 08-22-2016, 05:33 AM   #73
Originally Posted by retired on a mountain View Post
Had tires covers and my michelins still dry rooted 16000 miles 2 years old?Attachment 118017
Tire looks as if it had been parked in the dirt,,,
Does that make a difference,,, when in storage ???
Old 08-22-2016, 07:28 AM   #74
Yes just came home from campground . Lots of rain
Old 08-22-2016, 07:56 AM   #75
Lot of rain in many places !!!
I only ask because most believe we should not store our tires on dirt !!!
Old 08-22-2016, 11:51 AM   #76
Wolverine,,,,dirt will hurt.
Old 08-23-2016, 12:24 AM   #77
GreenImp's Avatar
Send a message via MSN to GreenImp
I was skeptical of the value to using tire covers but never ruled out that they were beneficial. After reading some recent posts on the subject I finally decided I would rather have them and not need them than need them and not have them. Once I received the covers I was curious about temps so I did a little experiment...I covered one tire only and took a bunch of temp readings.
Ambient temp was 66, one side of trailer had been in direct sunlight for 3-4 hours
uncovered tire in direct sunlight was 86 by the TPMS and 122 by the infrared thermometer
covered tire in direct sunlight was 79 by the TPMS and 98 by the infrared thermometer
shaded tires on the other side of the trailer were 64 by the TPMS and 68 by the infrared thermometer
I cant say if covers are going to make the tires last longer, but I can say that the covers keep them a whole lot cooler.
The two things that I find interesting are that the uncovered tires surface was nearly double the ambient temperature at the time, and that the TPMS readings (TST 507) were as much as 36 degrees lower than the surface temp.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 08-23-2016, 08:12 AM   #78
Cooler has got to be better !!!
Very good Info !!!
Old 08-23-2016, 09:28 AM   #79
BendOrLarry's Avatar
I think it's the UV rays that's the bigger issue.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 08-23-2016, 12:25 PM   #80
Scubanut's Avatar
In any case what's it hurt to throw on some $40 covers! Peace of mind. It also might be a good idea to store your trailer on some pressure treated lumber or patio stones. Keep them out of the damp ground. In my storage area I park on some 2x8 boards. The trailer settles those boards almost flush with the ground. If I was on the ground I'm sure those tires would sink a few inches.
2012 F150 FX4 Crew 5.0 3.73 gears
2O12 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
cover, tire
