Old 08-17-2015, 08:10 AM   #1
Toilet Clogs
We just moved from a fifth wheel to our Georgetown Motorhome. One thing we have noticed is that the toilet seems to be clogging more often. In the 5er, the toilet was mounted directly over the black tank. When you flushed, it dropped directly into the tank. Correct me if I am wrong, but it seems as if the toilet in the Georgetown is plumbed into the black tank. Things probably drop into a 90 degree elbow, run through a short length of pipe, then empty into the black tank.
Since we have been trained on the direct drop version in the 5er, we are probably not using enough water to do a complete and proper flush. We will work on that!
Our problem is most likely that the paper is not getting completely flushed out of the pipe, the next flush hits it and builds up until there is a clog.
Assuming our guess at how it all works is correct, what do others use to break up clogs in their systems?
Sandy and Shirley is offline   Reply With Quote
Old 08-17-2015, 08:14 AM   #2
TURBS's Avatar
Filling bowl with water is a must!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-17-2015, 08:18 AM   #3
We don't flush paper down the toilet as our 5er also has (2) 45 turns in it to get to the black tank. Use more water.
Old 08-17-2015, 08:52 AM   #4
Once there is a clog, what do you use to break it up and flush it through?
Old 08-17-2015, 10:41 AM   #5
Jim34RL's Avatar
I have had this issue in the past with other 5er's and had to purchase a flexible wand that my black tank hose will attach to. This is about three feet long with a shutoff valve. This is than drag through the camper and to the toilet. You turn the wand on when it is in the toilet and the seal is opened. You than push this down into the pipe to the clog working slowly so as not to make a mess. This works similar to a plunger but uses water in stead of air pressure to clear the clog.
Camping stores and RV centers sell them.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 08-27-2015, 08:30 PM   #6
Sbryant's Avatar
Once upon a time (prior to our Georgetown) we had a blockage and my DH used a regular snake. Worked great.
Sbryant is offline   Reply With Quote
Old 08-28-2015, 06:18 AM   #7
NO PAPER!
Papa GLS is offline   Reply With Quote
Old 09-26-2015, 09:23 PM   #8
Never really had that problem in my 2013 Class C sunseeker 3020DS. My dealer recommended that I flush left over ice cubes from the freezer down the drain before I dump the tank. Seems to clean out a lot. Then refill the tank with a good quantity of water and tablet.
Gchpazi is offline   Reply With Quote
Old 09-26-2015, 10:12 PM   #9
Done with this
Originally Posted by Papa GLS View Post
NO PAPER!
Oh, what you said!! Here come the flamers!!!
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 09-26-2015, 10:29 PM   #10
Ford Idaho's Avatar
Stranded
Stranded on a toilet bowl
Stranded
Stranded
What do you do when you're stranded
