Old 07-16-2016, 02:18 PM   #61
While all prior responses were great, I now advocate everyone do the following on new campers.
a. eternabond all seams to prevent roof leaks. Neighbor of mine with new camper notice d his RV was missing dictor in a lot of key places.
b. LT tires or as a minimum replace OEM ST tires with Maxxiss ST Tires.
Skyliner is offline   Reply With Quote
Old 07-17-2016, 09:18 AM   #62
BandJCarm's Avatar
You're on page 7 of a thread that lists all of 'em..............
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-17-2016, 09:35 AM   #63
Originally Posted by teamjendy View Post
My wife and I are first time RVers, taking delivery of a new FR3 next week.
I've been looking for a list of items that I will need to outfit the RV with. Every list google comes up with tends to be things like home furnishings, food supplies, first aid, etc. Although those are great reminders, we can fill our RV with things we use at home no problem.
I'm looking for a comprehensive list of technical or items that really make RVing a bit easier .. things that a first time RVer wouldn't know anything about.
I go to camping world's website and I see a bunch of things that I've never thought about (pressure regulators, surge protectors, battery upgrades, solar systems, etc.
With money not being an object, what items do you wish you had when you went on your first trip?
1. A higher pressure water regulator instead of the standard that comes with the camper.
2. A sewer hose that has sealed caps on both ends so there is no need to use the water hose rinsing at the dump station. Just cap it as you disconnect it and go.
4. A cordless drill for those who have manual jacks.
5. A 35 gallon portable tote for when the grey fills early.
6. A couple extra 25 foot white hoses.
7. A 50amp to 30 convertor if your not 50 already.
8. External lighting such as rope lights or a battery powered coleman else bugs will be on the camper.
9. A step for the ground if the lowest step happens to be to high.
10. A rinsable mat. I fold our 10 x 12 and hook a bungee around it for storage.
This is about all the odities i can think of.
Simplewon is offline   Reply With Quote
Old 07-17-2016, 09:38 AM   #64
A compressor/battery jumper from Costco. You can fill a trailer tire without running a cord.
mnoland30 is offline   Reply With Quote
Old 07-17-2016, 09:52 AM   #65
F150/Wildwood
Sun power?
I built from scratch a 100 watt solar panel that will be used to charge all the gizmos we seem to enjoy while camping...Kindle, iPad and such. I use it to recharge our second 12 volt marine battery while camping w/o services. It will charge the battery in a day or so and give me backup or as a source of energy to invert. Maybe the first few times out you won't need it!
Tim
Tmckamey is offline   Reply With Quote
Old 07-17-2016, 10:39 AM   #66
There are a ton more then 5 things .... I think I am going to end up spending more on stuff then I spent on the MH it self.
Alec
Eastover, SC
Prior Campers
1996 Coleman Sun Valley (1995 - 2002)
2017 Forester 3011 DS (2016 - Present)
SharpPI is offline   Reply With Quote
Old 07-17-2016, 12:21 PM   #67
You got it!
gfarmcafe is offline   Reply With Quote
Old 07-17-2016, 12:33 PM   #68
2012 Solera
Really only need one thing - credit card with a very high limit!
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-17-2016, 02:13 PM   #69
Solar
You don't need it right away, but if you want to boondock, you'll want a solar panel and a charge controller. I glued a 100 watt panel to the roof. Morningstar makes a great charge controller. I believe it is the SHS 10. Hook that up, and it will prevent a lot of issues, keep you batteries topped off all the time and make them last much longer. Mine puts out enough power most days to charge the batteries up by noon.
Old 07-17-2016, 02:26 PM   #70
Agreed- solar panel. Also; mattress memory foam topper; windshield and side window privacy covers; ceiling vent covers; vent foam inserts for black out purposes and heat/cold retention; screen door grill(for dogs) and horizontal bar on it. Tension bars for frig, upper cabinets and medicine cabinet to keep items from falling out.
mtnlvr is offline   Reply With Quote
Old 07-17-2016, 02:35 PM   #71
jeff64's Avatar
Lots of patience and some alcohol for when the patience wears thin
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 07-17-2016, 04:28 PM   #72
That was the first thing we got!
Alec
Eastover, SC
Prior Campers
