Old 01-11-2013, 07:12 AM   #1
Windsong/ Georgetown side doors?
On my windsong some of my side compartment doors on open horizontal to the ground (90 degrees) and some open past it to around 145 degrees. Is this normal or did the previos owner install the incorrect shocks?
av8erdunn is offline   Reply With Quote
Old 01-11-2013, 07:48 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Sounds like the closures may have been replaced with shorter than original pieces. Do any look newer than others? My coach has the doors with the hinges on the side so they open similar to a car door. The only door that opens horizontally is the generator access door. That opens a little past 90 degrees because the slide-out to the bedroom is just above.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-11-2013, 07:52 AM   #3
cfsoistman's Avatar
2006 Georgetown Brochure.pdf
Check out the pictures on page 7. This shows the doors in a open position. I originally thought the doors opened farther, almost straight up. It looks like past 90 degrees is normal so your 135 degrees is pretty close to what these look to be.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 01-11-2013, 08:38 AM   #4
Ya know, I didn't even think about the whole slide thing. I guess they can't open any further since they would hit. Thanks for the input, it's greatly appreciated.
