Old 03-21-2019, 02:32 PM   #1
Winterizing Class C MotorHome
Looking for rvers experience on winterizing a motorhome or rv. Which is better, using RV antifreeze or blowing out your system with air?
nuruls is offline   Reply With Quote
Old 03-21-2019, 02:35 PM   #2
PPST Wannabe
kenandterry's Avatar
This battle has gone on since RVs were invented.
Do whatever suits you. There’s no right or wrong.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 03-21-2019, 02:35 PM   #3
A32Deuce's Avatar
I blow mine out 3 times till there is no mist and,put RV antifreeze in the traps and enough to cover both gates. Put the water filter in a bag in the home reefer. This way since 2012.
A32Deuce is offline   Reply With Quote
Old 03-22-2019, 09:18 AM   #4
You might as well ask: "which is better Coke or Pepsi?" There is no right answer.
Some do one, some do the other, some do both.
Iwritecode is offline   Reply With Quote
Old 03-22-2019, 09:25 AM   #5
PPST Wannabe
I understood you the first time.
Ken and Terry
Old 03-22-2019, 02:10 PM   #6
Ham Call N8SAC
Maxwell D Pratt's Avatar
Why would blowing out with air be an option. When it takes 10 minutes and less than $10 to winterize with Anti- freeze . Tried one year with air . Cost me $350 to have piping fixed . Have been camping for over 50 years I learned the hard way.
Maxwell D Pratt is offline   Reply With Quote
Old 03-22-2019, 08:57 PM   #7
And a desirable side effect...
And a desirable side effect of winterizing with antifreeze is that it fills the traps.
Larry
Larry-NC is offline   Reply With Quote
Old 03-22-2019, 11:11 PM   #8
bikendan's Avatar
We live in Western Washington, a block from Puget Sound, so it rarely gets very cold, for an extended time. So I just drain the tanks, blow out the lines and put antifreeze in the toilet/p-traps.
Equalizer WDH
Old 03-23-2019, 06:57 PM   #9
Thanks for the info. I've winterized for years using RV antifreeze without any issues till this year. Just got ready to un-winterize my rig and found the water filter canister cracked and came off. No one ever suggested winterizing and then removing the water filter canister for the winter. Must have been a bead of water on the canister threads when I screwed it back on and it cracked during the winter freeze and fell off. Learn something new all the time.
Old 03-23-2019, 07:51 PM   #10
A32Deuce's Avatar
Had that happen to me once. Dry both threads real good now!
Old 03-23-2019, 08:04 PM   #11
I I also empty the canister into the toilet when done, so any expansion into it will not cause damage.
AbdRahim is offline   Reply With Quote
Old 03-24-2019, 09:01 AM   #12
Ham Call N8SAC
My filter was frozen and damaged that way when I got my camper . The guy that had it before me blew it out with air. After ordering a new filter Carthage case . I got tried of moping up under filter in cabinet . And bypassing To winterize renoved all of the filter on inside and use an external filter, much cheaper and a whole lot less trouble. I have a whole filter assembly if some one would want to pay shipping would give it to them .
class c, motorhome, winter
