Forest River Forums
Sunline User Photos
Go Back   Forest River Forums > Motorhomes > General Motorhome Discussion
Old 09-19-2011, 02:49 PM   #1
2011 Sunseeker 3120
Winterizing our 2011,forest river sunseeker 3120
Good afternoon.
Reading the owners manual and trying to find drain valve for fresh water tank and the bypass valve for the water heater. Unfortunately, we purchased our rv up in Ottawa, On, Ca, 375 miles away and help long ways away.
Looking forward to your replies
Thanks in advance
Gary
Garbet is offline   Reply With Quote
Old 09-19-2011, 03:57 PM   #2
itch'n to road trip
campnqueen's Avatar
Look where you hot water tank is... is if you can access the back of it.. under the bed, in a cabinet... where ever it is... NORMALLY the water shut off is in line with the rest of the water pipes going to the water heater.
Email you dealer and ask them to give you an idea where these items may be.
The drains SHOULD be marked on the outside of your RV... should say something like " drain" " low point"... look UNDER the RV and see if there are gray, red, or blue pipes sticking down... should have a screw off cap. Don;t forget to open ALL of the faucets and get a blow out plug so you can blow the water out of the water lines. Then run some pink RV antifreeze through the lines and in the sinks and toilet. Really not a hard job.... just time consuming. GOOD LUCK!
2007 Ford F-150 Lariat Super Crew Cab 4x4
2010 Cherokee Graywolf 19RR Toy Hauler
Paula, Ken, Shadow Wood & Sunny Delight
Jasper Ga. -
Nights camped 2011: 32
campnqueen is offline   Reply With Quote
Old 09-19-2011, 05:31 PM   #3
CRZ
Do you close the taps after adding the antifreeze?
CRZ is offline   Reply With Quote
Old 09-19-2011, 05:43 PM   #4
too fast turbo sled
f1100turbo's Avatar
Don't forget to drain hw heater turn bypass first.
also remove water filter.
don't forget outside shower.
close all taps when done.
you can also buy a kit to install antifreeze .....
DO NOT PUT ANTIFREEZE IN FRESH WATER TO WINTERIZE!
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
f1100turbo is online now   Reply With Quote
Old 09-19-2011, 05:44 PM   #5
yes you do close the taps..what model do you have. My 360 has the bypass underneath the coach under the water heater..there is a round disk you unscrew to switch the valves...
polkatronron is offline   Reply With Quote
Old 09-20-2011, 08:52 AM   #6
I have the same year and model. in the second storage compartment from the rear on the passenger side there is a pannel at the back of the compartment. it contains your water filter and to the right of it is a handle for your fresh water drain.
under your Sunseeker toward the rear are two hoses, one red and one blue. these are the drains for your water lines. open your faucets as you drain.
grandpa1 is offline   Reply With Quote
Old 09-20-2011, 09:02 AM   #7
too fast turbo sled
f1100turbo's Avatar
Also referred to as LOW POINT drains
Ron and Amy Benhart
» Online Users: 550
98 members and 452 guests
4bnabird, 4runner freak, 5Galvs, 87CrewDually, andrew963, bikergirl, BlakeB, bob213, bob34787, Bob_Loblaw, Ca Cardinal, camper_Lucy, Canuck_Doug, Cascade Bob, cat1956, cbconway, cdbus, concours14, cousin01, cstover, DAISY BOYKIN, danred, daveg, davegood, daveinpickerington, ddurnell, Diedrich, dimurrrw, dknight903, dlmurray51, DonG, donn, Doug DiLaura, dunnnc, fonzie, fordmantpw, GAS MAN, go_cubbies22, grhodes50, Happy Vibe, herk7769, hjmiberry, Hob, Iggy, jacksum2, jamiller45, jdefeo1, jkinger, Jo54, johnthecamper, Jonesy, Joseph5410, jsutherl, kathomas, Kmckruit, LauraW, LChance, leayellow, lemoj1, LeNe4847, lmcleister, Lonewolfcry, Loui, mcbride5, merlin66043, mhartzel, micalo, MilCop4523, NeilM108, ng2951, nuisance, Painless, ParrotHead, pchrcane65, photog, Poppy Bill, ret2006, RJHuser, rschoono289, sabre5er, Sailfish Bret, SCOC, Scriggs1, SDENN4281, Sg6923, sideout1961, simon, texwolves, Triguy, trudinator, T_LMurphy, VTX Al, wayne anthony, Wilkrich, william.migues, wvbike_99, wvcampers, Zama
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
