Old 06-04-2012, 10:18 PM   #1
16UL Weight Load on Door
How much weight can the door support on loading the trailer for a 16UL? I would like load a Kubota BX mower at 1500lbs.
Thanks!
yellow_se is offline   Reply With Quote
Old 06-04-2012, 10:45 PM   #2
Hello and to the forums. While you have a nice question, no one here is qualified to answer. Look up DCASTEEL under search, advanced, and usernames. He is a factory rep. Shoot him a private message if need be, and he should be able to give the factory number. The last question on ramp weight was for a 34fbk (think that is the right model), and the answer was 2500 pounds rolling weight, one axle at a time. Your Kubota is going to be on the ramp all at once, not long enough for only one axle at a time.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-05-2012, 06:30 AM   #3
Thanks Windrider...
