I put mine on the wall closer to the connections. but you have to figure out where a stud is hiding or it will pull out of the wall the studs are 2x2s and I used a inch/1/2 lag bolts to secure the mount you have to be careful not to go through the wall on the outside or through the roof.I take the tv off and lay it on the bed when traveling this eliminates any bouncing and insures the tv is safe while traveling you have to get the right mount so you can remove the tv,
Had trouble finding the correct TV bracket to match the exterior bracket on TT, found both pieces at Universal Polymer TV / RV Computer Monitor Bracket --2 piece set--(BLACK) | eBay. Only $17.95 a set. Fasten one to the TV wall mounted bracket, other to the back of the TV itself. Very easy to lift up & off when needed.
Thanks. Does your bracket swing out from behind the refrigerator?
I put mine beside the cabinet above the kitchen sink and from here I can swing it out so we can watch it at our dinette or I can swing it the other way and we can watch it in bed I found mine on ebay for about 19.00 bucks It fits a TV up to 30 inches. mine is a 24inch flat screen.
