Old 11-27-2014, 06:02 AM   #11
Iwannacamp's Avatar
Poor ole' Dodge. Better brush him down at night and give him some sweet feed.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 11-27-2014, 09:06 AM   #12
That poor 'ol Dodge pulls it at 80 just fine. I am sure just like yours does
1990Desert is offline   Reply With Quote
Old 11-27-2014, 09:24 AM   #13
Taranwanderer's Avatar
Going from a ST235 80r16 to a LT235 85r16 shouldn't increase your tire diameter, only width...? A 235 is a 235. Am I missing something?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 11-27-2014, 09:32 AM   #14
BombDoc's Avatar
I went through this yesterday at a tire dealership while getting new tires on my wife's car. If you go from a 235 80R 16 to a 235 85R 16, you are increasing the side wall height by 5mm. My issue is I have about an inch between my tires now and losing any more space there concerns me when making tight turns. I'm not sure what the minimal acceptable clearance is between the tires. I'm not worried about increasing the height 5mm and want a tire I can do 70mph on. Still looking.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is offline   Reply With Quote
Old 11-27-2014, 09:44 AM   #15
TURBS's Avatar
It'll raise it 1/4 to a 1/2 inch
TURBS.
Old 11-27-2014, 01:33 PM   #16
235 is the width, the 80 or 85 is the aspect ratio. Going to the 85 light truck tire added about an inch. After pulling it this past summer I had zero problems. As others have noted, you do have to watch your load rating with LT tires. They are not rated as heavy as ST tires. I am still ok on my setup on load carrying.
Hello Desertvet from a fellow RZR forum member!
Jbbooks is offline   Reply With Quote
Old 11-27-2014, 04:11 PM   #17
Fulltime family RVer
I'm have the same issue - the space between my tires is very close. Any increase to both tires will make it exceptionally close.
Old 11-27-2014, 04:55 PM   #18
wmcclay's Avatar
LT tires must have a twenty percent safety margin and are rated at max mph. I put bf Goodrich commercial ta's on my Sanibel. Gained 1-1.5 mpg, have had them on a year and 20,000 miles. Easier ride, This is the second rv with them. Not a flat or blow out, unlike my ST tires made in China.
This is and most likely will always be a hot topic on this forum. I would much rather have a tire made in usa, safety rating of 20%, rated at 99 miles per hour and to carry passengers, Than a tire rated at 60-65 mph with no safety margin and not certified to carry passengers.
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
Old 11-27-2014, 05:08 PM   #19
Whats Up Jeff
Old 11-27-2014, 05:22 PM   #20
I guess my other issue is that the LT tires usually have a lower load carrying capacity than ST tires in equivalent sizes and load range.
tire, tires
