Old 09-17-2013, 09:51 AM   #1
275ULSBS Ground Clearance
I ordered an Ultra 275ULSBS.
Looking at one on the dealers lot, the ground clearance may be a problem for me.
Anyone have any ground clearance issues?
Anyone ever have their Ultra lifted about 4?
GeoFish
Geofish is offline   Reply With Quote
Old 09-18-2013, 11:24 AM   #2
GeoFish
My 16UL Ultra Work & Play is only 21.5 feet long overall. It has the same suspension and axles (5k) as the larger Work & Plays. Even with the shorter length, I still have to be careful backing it into my driveway (has a slight incline) or pulling into some gas stations. I'm sure other Work & Play owners (especially those who own longer W&P's) will chime in. In any case, I did notice there are two bolt openings where the suspension shackles bolt to the frame. Mine is bolted to the lowest opening. The higher opening would provide an extra 1 - 1 1/2" of ground clearance. Not much, but might be helpful.
wp_owner is offline   Reply With Quote
Old 09-20-2013, 09:18 PM   #3
1l243's Avatar
I would not even take mine on a dirt road... Well maybe but no pot holes...
1l243 is offline   Reply With Quote
Old 04-13-2014, 09:13 AM   #4
I had the dealer reverse the axle on the leaf springs on our 25 ft. W&P It gives a lot more ground clearance. Just pulled it from Snow Lake, NM to Winston, NM with two four wheelers in it. If you are familiar with that road you will say We are nuts! Pulled it with my 2005 F250 6.0 four wheel drive. Worked great but still a major challenge.
Bhooner is offline   Reply With Quote
Old 06-27-2014, 08:41 PM   #5
We also custom ordered ours and had the dealer flip the axels during the build...so glad we did, since we drive a lot in the mountains and on bad roads.
EBendana is offline   Reply With Quote
Old 06-27-2014, 10:56 PM   #6
My UL275 which is 33' is set on top bolt holes and I have plenty clearance, at least as far as I can tell, but I'm the only one driving so I have not had the chance to watch the trailer pulled into the back yard
rblack22 is offline   Reply With Quote
