Old 09-22-2016, 09:17 PM   #1
34WRS How Does It pull?
Does anyone have or know someone that has a 34WRS? We just sold our 20ft WPT and really like the 34WRS but I'm worried about how it pulls being that big? I will have to upgrade my hitch on my truck to a class 5 right out of the gate and get a weight distribution hitch that can handle it. I have a 2010 Dodge Ram 2500 with the 6.7 Cummins in it. By all the numbers it's good to pull it and I already have air bags so I have that in my favor. Looking for real world experience now.
swthpk32 is offline   Reply With Quote
Old 09-23-2016, 07:45 AM   #2
Its such a rare model, its going to be hard to find someone here who has experience. But hopefully, someone will chime in.
I had a 30WRS for a year and a half and put over 8000 miles on it for around 20 race weekends. I had an Equalizer 4 Point hitch and once I set it up properly, it handled extremely well. As good as any fifth wheel I've owned.
I think the key is your hitch. Get a quality hitch and make sure its set-up properly. The tongues on these things are very heavy. Mine was 1500 lbs. unloaded. But once I had the Equalizer set correctly with some real tension on the bars, the sway control was fantastic.
2015 F350 6.7L Lariat CC LB
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is offline   Reply With Quote
Old 09-23-2016, 07:48 AM   #3
What hitch setup did you use? Dealing with an 1800lb TW has been a challenge to find a hitch to handle it!
Old 09-23-2016, 07:49 AM   #4
One more thing. I like the fact you're getting a real class V hitch. I had the Curt from etrailer rated at 20,000 lbs. Great hitch.
When you get the WD hitch, make sure the shank is also a 2.5" shank. Using a reducer on a 2" shank just makes slop and is sometimes not recommended.
2004 Puma 30FQSS
2010 Sabre 31QBDS
Old 09-23-2016, 07:50 AM   #5
That Curt I mentioned has a tongue weight rating from 2700 lbs. I believe.
2004 Puma 30FQSS
2010 Sabre 31QBDS
Old 09-23-2016, 07:53 AM   #6
Good to know! I was looking at the Curt setups to. Had it on my 20ft WPT and you didn't even realize the thing was back there.
Old 09-23-2016, 07:23 PM   #7
By the way. What area are you in?
2004 Puma 30FQSS
2010 Sabre 31QBDS
Old 09-23-2016, 07:36 PM   #8
Central IL
