Old 04-11-2015, 03:38 PM   #1
AC Drain
I loaded my new 18 EC back up from our first trip and there was a lot of water on the roof. Where does AC drain at? Should I set up with trailer leaning toward rear? It was level during our stay. How do I set up for extended time at home to best maintain the hauler.
Jajernigan is offline   Reply With Quote
Old 04-11-2015, 08:59 PM   #2
The AC does drain on the roof. A slight lean toward the rear helps put the water where you want. At home you can tilt it more if your fridge isn't on.
Old 04-12-2015, 01:22 PM   #3
northstar1960's Avatar
you may be able to extend the drain with some vinyl hose to get it off the roof
northstar1960 is offline   Reply With Quote
Old 04-16-2015, 10:42 AM   #4
1l243's Avatar
A very slight tilt to the rear is not a bad idea but I don't think that water on the roof will hurt anyting. If it builds up enough it should find it's way off the roof. Mine will trickle down at the rear of the trailer...
1l243 is offline   Reply With Quote
drain
