Old 03-04-2015, 01:07 PM   #11
1l243's Avatar
Fort Worth TX.....
1l243 is offline   Reply With Quote
Old 03-29-2015, 09:09 PM   #12
gashog's Avatar
Originally Posted by 1l243 View Post
Center pin on 7 pin connector is for reverse or back up lights. Mine had the wire but was not connected. Once conected the center pin was hot when in reverse.
I ran a wire, fuse and realy from the junction box to the rear ramp lights. Works pretty good.
Very impressive, Would like to know more about the relay? Where did you find the it?
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 03-29-2015, 10:58 PM   #13
1l243's Avatar
It's a basic 12 volt light relay, you can get it at any auto parts store. They come in Four or Five terminal depending on wiring, four terminal is best or you can not use 87a on a five terminal. You also want to run a fuse between the relay and battery.
KC HiLiTES® 3300 - 12v 40 amp Relay
http://www.therangerstation.com/tech...ms/relays1.jpg
Old 12-03-2015, 04:50 PM   #14
OK, this winter installing back up lights is on my list to do..
I am new to the TT world and have a newbie electric question. I have read in many postings about a "relay".
I understand the wiring from the 7 pin and following it back to the junction box to splice into to power the lights.
I understand the idea of putting an inline fuse (what size?) to protect the circuit.
I don't know what kind of relay or why I need the relay. Can you guys help me out?
Greg
Curry's
2014 ROO 24 IKSS
2012 F150 Quad Cab Eco Boost short bed w/tow package
fyrdad is offline   Reply With Quote
Old 12-03-2015, 06:37 PM   #15
2007 WildCat 32QBBS
05CrewDually's Avatar
Greg
If you use LED flood lights there's no relay needed.
If you use halogen or a high amperage bulbs a relay is needed. The relay is basically an electric solinoid switch. A small gauge wire is used to trigger the solinoid to pull close contacts. The contacts can handle the high amperage draw from the halogen bulbs.
Typical schematics and explanation here: http://www.r1200gs.info/howto/relay.html
05CrewDually is offline   Reply With Quote
Old 12-03-2015, 07:35 PM   #16
Crew, I've read of folks who are installing LED lights, (the type I am going to install) and included the relay. Is it just an extra then?
Curry's
2014 ROO 24 IKSS
Old 12-03-2015, 08:37 PM   #17
2007 WildCat 32QBBS
I run 2 round LED lights using stock plug wiring and a single14ga wire with no relay to the lights. The current draw isn't enough to warrant using a relay. The wiring can handle atleast 15 amp alone. My two lights are well under 1 amp.
This is the only file pic I have. 1 on each side of the hitch on an angle facing out.
What is the draw of the lights you're using? Check the specs sheet.
light
