05-21-2018, 02:12 PM
Air in water
I have tried and tried to get the air out of my water system. Is there a simpler solution? The pump runs, but never shuts off.
05-21-2018, 02:29 PM
Looks like your pump is sucking air - a reverse leak so to speak. If you have a winterizing valve for inputting antifreeze, make sure that valve is not partially set to the AF input hose. Make sure the valve is not cracked/damaged. Check the strainer/screen on the pump for freeze cracks or for loose connection.
05-21-2018, 02:35 PM
Broken Toe
The pump is supposed to shut off when a certain pressure is reached on the lines (which cannot be reached with a faucet open) Air in the water lines will compress and still cause the pressure to rise letting the pump stop. If pump cycles on and off, you have a leak somewhere. If is just runs all the time, you are either not picking up water on the suction side, your pump rollers are shot or your pressure switch is bad.
Good luck!
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
05-21-2018, 02:59 PM
Just as confused as you
Water is 2 parts hydrogen and 1 part oxygen, so of course you have air in your water.
Sorry, I know that doesn't help your problem, but I just had to say it.
Richard & Jill
05-21-2018, 03:14 PM
Those parts make up water but they don’t make up air exclusively.
05-21-2018, 03:18 PM
Broken Toe
air is 78.% nitrogen, 20% oxygen, 1% argon, 0.04% carbon dioxide, and small amounts of other gases. So unless you take out the hydrogen and add a whole lot of nitrogen, you don't have "air' in your water.
Sorry, but the science nerd in me had to say it.
Tim
05-21-2018, 03:28 PM
How long has the pump ran? after dewinterizing mine took about 4 or 5 minutes. I was just about to give up thinking something was wrong when it finally spit out the last air,charged and stopped.
05-21-2018, 03:48 PM
Forgive me for asking, but you did put water in the fresh water tank, right? Just connecting to fresh water does not fill the tank.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
05-21-2018, 04:00 PM
Tim
And lack of self control.
05-21-2018, 05:09 PM
Broken Toe
Sometimes, I'm like Roger Rabbit with Judge Doom doing the "Shave and a Haircut" thing...
Tim
05-22-2018, 05:08 PM
It was a loose fitting on the water pump, sucking air. Thanks to all who replied.
05-22-2018, 09:33 PM
Broken Toe
good deal. Glad you found the answer.
Tim
05-22-2018, 09:50 PM
Sucking air indeed! Yes, thanks for reporting back. This thread might help others with the same issue.
