Old 10-26-2013, 07:20 PM   #1
johnl222's Avatar
Anyone have any sugestions on mounting TV'S in a 30WR OR 30 WRS?
I need to mount some TV's. Need advice on length of screws and any pics would be awesome
johnl222 is offline   Reply With Quote
Old 11-06-2013, 03:39 AM   #2
1l243's Avatar
I have a WR. It came with a 15" TV mounted in the wall in the bedroom. It has a TV location on top of the Pantry in the livingroom so a TV just sits on top of the pantry. I did add a 19 inch TV to the garage. I used a mount similar to this. I mounted it to the wall cabinet so I did not have to bolt into the wall.
Sanus Double Arm Full Motion Wall Mount
1l243 is offline   Reply With Quote
Old 11-07-2013, 09:35 PM   #3
If you mount anything substantial (more than 16 oz) to an outside wall, you have to drill completely through. At that point you need to use the special fastener called a "camtainer" that seals the hole so water doesn't get to the plywood behind the gelcoat surface.
Any W+P dealer can supply you with these fasteners. That's how they mount the TV to the wall.
beyerjf is offline   Reply With Quote
Old 11-09-2013, 10:25 PM   #4
johnl222's Avatar
I got them mounted. They were on interior walls. On the bedroom one I screwed into studs. The backing board was to low to mount to. The living area one was in TV backing board area.
ID:	42460   Click image for larger version
