Originally Posted by OldGal3
Jack- are you talking about the plastic guide near the floor right where the door frame is? Where did you get it? Or did you go with something a bit more sturdy? The plastic strap on mine broke also, but I've found that on Amazon. Thanks.
[SIZE="4"]The door track (guide on top) was bent and damaged on delivery to the dealer. It was then bent back into the original shape by the dealer. The door evidently broke off during delivery and was lying on the bed. The small plastic guard at the bottom has been damaged also.
Chas Hood with FR sent me a new track and the door hangers but not the guide at the bottom. The new track is much sturdier and should work fine. This should prevent it from coming off the track and a new bottom guide will keep it snug during travel.
Jack/SIZE]
