Originally Posted by 5picker
Just throwing this out... if you winterized using an antifreeze inlet where you need to turn a valve to select antifreeze or fresh tank, did you turn the valve back to the fresh tank?
Easy to forget.
I did that, easy to do and then I still forgot to open the fresh water tank valve before the pump. If you had water in the tank did it freeze? My monie is on you forgot to turn a valve, really easy to do. It's not like we all do that daily, hope you find the problem. If not just take bottle water with you
