08-14-2018, 08:49 AM
Generators
We are trying to determine what is the best generator and size to purchase for our 18ec work and play. To be able to run the AC, Refrigerator, Hot water tank, Stove etc. We are currently looking at the Champion 3500-Watt RV-Ready Dual Fuel Portable Inverter Generator which is also a 3150-Watt on propane. Can you give your recommendations. Want to make sure we have a strong enough generator.
08-14-2018, 10:45 AM
If you have 30 amp service and one A/C then the 3500 watt genny should be plenty. However, if you have 50 amp service you're going wish you had a bigger genny.
Gotta go campin!
08-14-2018, 11:07 AM
Also look at the HF Predator 3500 watt genny...
If you have 30 amp service to your trailer either the Champion or the Predator will work...
if you plan on using propane for fuel, look into run times on a 20# tank... you might be surprised at how quick they get used up...
2014 Shamrock 183
08-14-2018, 11:22 AM
Blog: RVroadtripper.com
The ones that can handle are 50watts are just to darn heavy. 200# or more. My Champion 3500 is 85#.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
08-14-2018, 12:00 PM
I think that you will be borderline at best with that generator. I had a Champion 4000/3500W generator that I used on our 26RR, and it barely ran those loads on a warm day. When the temps got into the 90's, it had a hard time running just the AC, fridge, and converter. I then went to a Honda EM5000SX and never had an issue. I believe that the biggest reason for this was the engine size.....the Champion had a 6.5HP engine, while the Honda was 13HP. This was definitely noticeable during large load starts....the Champ would bog really bad, and the Honda barely changed speed.
I now have a Honda EU7000is.....its a heavy beast, but has enough wattage to power mine and my neighbor's camper when it is 95* outside. Plus, if/when we upgrade campers, it will power those too.
2016 26RR and a 2018 OR371MBH
08-14-2018, 05:01 PM
if your 7000 /5500 runs two campers and ac's then a 3500 should run one . the honda 3000 is only a 163 cc motor the 7000 is 389 cc but only 5500 running watts . i think the champion 3500 inverter 3200 watt running is more then enough to run any 30 amp rv .
08-14-2018, 08:15 PM
I didn’t say it wouldn't.....I just said it would be borderline based on my experience with a Champion Generator with similar specs. On hot days, power draw from the AC can vary widely..... I’ve seen up to 500w variances from early morning to afternoon when it’s hottest. And while I did run 2 campers, the one on the 20A circuit was rigged for reduced electrical. The only things running were the AC and converter. Steady state load was around 5300W with spikes to 8k when first starting the 2nd AC.
08-14-2018, 08:31 PM
Your stove is propane and WH and fridge can be propane as well.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-14-2018, 08:43 PM
What kind of stove do you have? I doubt you will be able to run the A/C 1500 watts and the water heater 1400 watts plus the refrigerator and the stove. The startup amps of the A/C will probably put you WAY over the top. Connect to a 30 amp and see if you can get by on that. If you can then that is 3,600 watts.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
08-14-2018, 08:46 PM
THIS ^^^
It will save you a lot of extra generating capacity (probably 500 watts on the fridge and 1500 on the water heater). The fridge uses very little propane, and if you only fire up the water heater when you need hot water, you will also use little propane.
08-14-2018, 08:53 PM
We have a Suburban SDN2 gas
08-14-2018, 09:14 PM
Suburban SDN2 gas stove
08-14-2018, 11:50 PM
I'm Lost
Your Champion geny on LPG will give you approximately 26 amps.
Keep in mind as the genset gets heated up the output goes down, if the manual is good it should show you the temp/output curves.
Our 60KW Kohler genset can loose 10% of it's output on 35c/90f days.
Cheers,
Geoff
Geoff, Francesca and Lucy the Golden holy terror (I mean retriever, BD Nov. 2018)
2023 F150 Screw, 3.5L, HDPP, LT tyres.
2013 Rockwood Signature 8310SS
2023 F150 Lariat 502A (After all rebates, price protection and dealer discounts, I saved $12,600Cdn. (Cavalcade Ford). If pays to shop dealers! (April 2023)
08-14-2018, 11:56 PM
I'm Lost
Originally Posted by Bluepill
THIS ^^^
Bluepill is correct, run your LPG appliances on gas.
Why convert propane to mechanical energy, convert mechanical energy (your inefficient 4-stroke engine) to electrical energy, then convert that electricity back to heat to heat your water and cool your fridge; use your propane to go directly to heat and do it's heating and cooling as required.
That leaves you gobs of expensive electricity to run your AC!
Geoff
08-15-2018, 01:37 AM
I really like the champion dual fuel but did not want to move 100lb unit around. I bought the Micro Air Easy Start for the AC and one Westinghouse 2500 gen. At $569 (I think) and 48lbs I can buy a second one if I need to link them for additional power.
+1 about running fridge and WH on propane and only as needed.
