Old 08-29-2016, 07:37 AM   #11
Keystone's Avatar
I think it will be far stronger that the original one Harry-O !
2015 W&P 25CB/ 2011 F250 6.7L Diesel
2015 HD FLRT/2009 HD XL1200L
US Army, 1979-1990 95BZ6
Keystone is offline   Reply With Quote
Old 08-29-2016, 08:03 AM   #12
Usually Confused Member
emm-dee's Avatar
What are y'alls opinion on having the entire interior side of the door coated with something like Line-X? Seems like that would work well, plus it would enable a lot more traction while loading/unloading.
I've used silicon seal around all the interior side trim and on all the outside fasteners but it would be a lot easier to just have the inside sprayed.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 08-29-2016, 09:21 AM   #13
Keystone's Avatar
I see no reason to not coat the ramp with a bed liner type coating. I used one on my homemade toyhauler. Worked great for traction.
Old 08-29-2016, 11:28 AM   #14
Cajun Style's Avatar
I purchased a can of Herculiner to coat the ramp door, My brother trimmed the wood with it
Harry-O
Cajun Style is offline   Reply With Quote
Old 08-29-2016, 11:32 AM   #15
I'm at work we will start on it again Thursday to put it back together,
Harry-O
Old 08-29-2016, 04:05 PM   #16
emm-dee's Avatar
I'm going to get a quote to have this done. I'm not really too worried about leaking since it appears to be sealed pretty good now. But, when the ramp gets wet it's slicker than pig snot. Even dry, when unloading, the front brake on my Harley will easily lock up the front wheel and it just keeps going. To get around that I put the bike in gear (not running) and slip the clutch (can't use the brake because both feet on the ground) just enough to slow things down. Works well but would rather use just the brake. I have the bed sprayed in my truck and it's almost impossible to slide things around on it...even when wet.
Old 08-30-2016, 01:31 PM   #17
Retired JSO's Avatar
I added a flap on the door and while doing that, painted the entire door with gray paint loaded with anti skid. I busted my but the first time out before the paint. Seems to work way better than stock crap.
Retired JSO is offline   Reply With Quote
Old 09-01-2016, 08:07 PM   #18
More pictures Click image for larger version
Name:	ImageUploadedByForest River Forums1472774800.770277.jpg
ID:	119176Click image for larger version
Name:	ImageUploadedByForest River Forums1472774825.517720.jpg
ID:	119177Click image for larger version
Name:	ImageUploadedByForest River Forums1472774855.397082.jpg
Harry-O
Old 09-01-2016, 08:10 PM   #19
Really like the diamond plate.
Old 09-01-2016, 09:15 PM   #20
Keystone's Avatar
Nice!
door
