Originally Posted by Flybob
This thread made it all the way to post #52 before there was any discussion of a leak and OP said there is none. A flat roof that does not drain completely is not a design flaw. We all shop in stores every day that have flat roofs that may hold water. The fact that the caulk may fail eventually and it will leak is true of to every RV out there. That is why you are encouraged to inspect all caulk regularly. The weather and movement is tough on RV seals ( caulk). Your comment about not being a seamless roof is incorrect. There is no RV (that I know of) at any price where the entire shell is one piece ( no seams). There are no seams in your roof. You bought this RV to enjoy and have fun. The water on the roof should not prevent you from doing that.
I cannot stress with enough emphasis, how important it is to regularly maintain ALL your seals, not just the roof and inspect ALL the seals at least bi-annually and reseal any compromised areas with the appropriate sealing caulk, whether it's Dicor or Eternabond or Sikaflex.
It states that in every owners manual but it does not stress the importance of a regular and regimented inspection.
The one thing that will assuredly destroy your RV is water intrusion and the resulting rot and mold growth and if left unchecked, the eventual destruction of the RV not even taking into account the mold spores floating around inside that could kill you are at least make you sick.
There are a few relative fool proof ways to determine if your seals are leaking and recaulking is necessary but actually doing a careful visual inspection of every inch of seal is the easiest way, but you have to do it to determine if you have a leak.. Before it's too late for your RV.
While neither here nor there on this thread, it's something every owner needs to to, from a pop-up to a diesel pusher to a Super C. They all have caulked seams and they all can leak.
