Old 01-29-2014, 07:27 PM   #1
1l243's Avatar
Jack Antenna
I am not finding out much information on installation of the Jack antenna on a Work And Play. My concern is the construction of the roof of the work and play. It is aluminum skin over thin Luan which I think just runs down the center of the roof. It is not a walk on roof. I want to replace the Omni Directional saucer type antenna that came with the 30WR with the Jack antenna. The Jack anteanna is not just simply bolted to the roof but a hole is drilled though to the inside so it can be turned from inside the RV. I would put the Jack antenna in the same spot as the Saucer antenna...
If anybody has any experience with this I would like to hear it.
1l243 is offline   Reply With Quote
Old 01-29-2014, 11:54 PM   #2
SYE
SYE's Avatar
I installed one on my 2000 Cardinal. After I repped of the other 2 antenna's I realized I had a leak, after further investigation, I realized all of my wood on the roof was rotten, so I bought the mounting plate for the Jack antenna, the mounting plate was big enough to cower the rotted wood. I did not have to drill the hole since the wood was rotten but it looked real simple, I sealed it with the lap sealant and it was a done deal. And the reception was much better than my Winegard's that were on it. I hope this helps!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 01-30-2014, 12:30 AM   #3
PPST OGCDG
Frank-VA's Avatar
I installed the Jack antenna as a replacement to a windguard. I just changed the head. I went from receiving 2 channels to receiving 14 a my home. I have tried it at a campground with out raising it up and it received channels. The Jack is not as directional as the old windguard.
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
antenna
