Old 11-25-2014, 06:52 AM   #1
Ricochet's Avatar
Loading Procedure Question
Our 30WRS is our first toy hauler. I'm going to load a Harley trike in the rear. The trike weighs about 1200 pounds. Should I load the trike with the trailer rear stabilizers down? Should the trailer be on the truck hitch? Safety is paramount, so any help is much appreciated.
Rick
2015 Work and Play 30WRS
2011 Ram 2500 I-6
Ricochet is offline   Reply With Quote
Old 11-25-2014, 12:23 PM   #2
HarrynSally's Avatar
I do both i hook it to my truck and i use my tongue jack to lift the front as high as i can then i put the rear stabilizer jacks down tight and secure then i put the door down and drive the trike in and strap it down tight.
HarrynSally is offline   Reply With Quote
Old 11-25-2014, 01:08 PM   #3
I load my wife's Goldwing Trike with the trailer hooked to the truck and the ramp down...no stabilizers. Works fine. We have a Cherokee Wolfpack 27WP. I put my two wheeled Goldwing in front of her Trike.
Roger WJ is offline   Reply With Quote
Old 11-25-2014, 01:41 PM   #4
Ricochet's Avatar
Thank you for the responses. I have enough trouble with mishaps without creating any of my own...
Two fellow trikers respond! How cool is that! Do either of you hang out over at TrikeTalk.com?
Rick
2011 Ram 2500 I-6
Old 11-25-2014, 06:31 PM   #5
Valkyrie trike here and no support jacks. But keep in mind its in a different trailer.
Just have it hooked up at least. If not, Support jacks AND chock Blocks!
1990Desert is offline   Reply With Quote
Old 11-25-2014, 10:33 PM   #6
I don't but will go and check it out.
Old 11-25-2014, 10:56 PM   #7
Registered as Harry-O
Old 11-25-2014, 11:12 PM   #8
1l243's Avatar
I have a 30WR and I will either have the trailer hooked to the truck or if it's not hooked up I would have the stabilizer jacks down when I load my Ultra Classic... I have the trailer level when I load my bikel. Your trike might run lower so the first time you load up, I would go easy over the threshold from the ramp to the garage and have someone watch to check your ground clearance.
1l243 is offline   Reply With Quote
Old 11-26-2014, 09:26 AM   #9
Ricochet's Avatar
Thanks for the advice. I think for safety's sake, I'll have the trailer on the hitch and the rear stabilizers down. I will start with the trailer level, and go very slowly loading up the first time, and have the wife watch the situation. I can adjust the trailer height if I have clearance issues.
Rick
2011 Ram 2500 I-6
Old 11-26-2014, 09:27 AM   #10
Ricochet's Avatar
Just said hello to you! I'm registered as Rick Kay
Rick
2011 Ram 2500 I-6
