Yep, been using them for a most of the year. They have made some changes since I bought in the early spring. The most important is that the feet for the tanks are now made from aluminum. That keeps them from crushing the way the rubber feet did and they are soft enough to bend the tabs in to tightly clamp on the tank rim. The support group is very helpful, too.
One tip that I learned from the Mopeka tech support is to put a dab of petroleum jelly on the sensor pad when placing on the tank. That gives a good sound-conducting connection between the pad and the surface as well as making sure the pad doesn't stick to the tank bottom. (That happened to me once, earlier in the year-- AP Products sent a replacement sensor free of charge.)
