Old 04-13-2012, 08:23 PM   #21
hotrodj125's Avatar
The HERK just seems to have ALL the answers--- the master of answers..
hotrodj125 is offline   Reply With Quote
Old 04-13-2012, 08:39 PM   #22
The Herk's numbers are for 1/2" studs only.
Old 04-13-2012, 09:46 PM   #23
1l243's Avatar
I am thinking I have the Flagstaff series 04
1l243 is offline   Reply With Quote
Old 04-14-2012, 07:01 AM   #24
Now you have to determine if they have 1//2" or 9/16" studs. If the nuts takes a 3/4" socket it has 1/2" studs, if it takes a 13/16" socket it usually has 9/16" studs or it might take a 7/8" socket for the 9/16" studs.
Old 04-14-2012, 07:20 AM   #25
M109Rrider's Avatar
Not always true. Mine are 1/2 (stamped on chrome acorn nut) and takes a 13/16
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 05-20-2012, 11:20 AM   #26
M109Rrider is correct, I should have checked before I posted, I just checked mine, and they are 1/2" studs and take a 13/16" socket. Lugs are different than standard hardware as a 1/2" bolt/nut takes a 3/4" wrench/socket. So, once again, "open mouth, insert foot". Sorry about that. I will torque mine to 110lb/fr which is the mid point of the specified 90-120 lb/ft.
File Type: pdf Flagstaff TT Alum Wheel torque specs.pdf (311.4 KB, 132 views)
