Old 04-04-2016, 11:51 PM   #11
Have you put yours in it yet? My samurai has a bit of room but I don't think I would want it to ride between the stove and cabinet.
powerstroked is offline   Reply With Quote
Old 04-04-2016, 11:56 PM   #12
I have about 6 inches before my tire hits the cabinet. The bumper and winch will be up farther In front of the cabinet. It's gunna be a tight fit. Weights right under 4K
bajeep93 is offline   Reply With Quote
Old 04-05-2016, 06:06 AM   #13
Keystone's Avatar
Powerstroked and/or bajeep93, what technic do you use to secure those inside of the TH? Looking for a better way for my trike. Right now I have been using a rachet strap on each side of the rear axle and chocks. But I have had some movement while trailering (not allot, maybe 2-3 inches).
2015 W&P 25CB/ 2011 F250 6.7L Diesel
2015 HD FLRT/2009 HD XL1200L
US Army, 1979-1990 95BZ6
Keystone is offline   Reply With Quote
Old 04-05-2016, 08:01 AM   #14
I have not hauled mine in the trailer yet. Just got it. The way I have hauled mine for years I had no room for movement.
As you can see if it moved it would fall off. I have been thousands of miles like this with no problems. I use good macs car trailer straps. I tie from the back axle forward. The back ones I cross. The front I tie straight back off the front axle.
Before I haul the jeep in the new trailer I half to put new tie downs in the floor for it. There is a cross member under the center of the garage floor that I plan on hooking my 5000lb Tiedowns to. All four of the tiedowns will be in a straight line across the floor
Old 04-05-2016, 09:47 AM   #15
I haven't attempted to tie mine down yet inside the trailer but I plan to use axle straps and do all 4 corners with those then do one in the middle on the front and back to take out any suspension bounce as I go down the road.
Old 04-05-2016, 09:48 AM   #16
Are you going to put different tie downs in there for it
Old 04-05-2016, 09:58 AM   #17
My samurai is only about 2000 lbs as it sits and I think each tie down is rated at 2k so I doubt it.
Old 04-05-2016, 02:55 PM   #18
Keystone's Avatar
Thank.
Old 04-06-2016, 11:07 PM   #19
Cajun Style's Avatar
What year and kind of trike do you have?
Harry-O
Cajun Style is online now   Reply With Quote
Old 04-07-2016, 06:29 AM   #20
Keystone's Avatar
As my signature says......
Two wheel bikes are no issue. use a condor. Trikes don't like condor type chocks (too much weight transferred to the neck).All of the HD factory built trikes have ties down on the rear axle. After 7 years of ownership I've come to the conclusion that there has to be a better way. Maybe something similar to what many car haulers use. Harness that goes over the rear wheel?
