Old 06-14-2014, 08:50 PM   #1
New to us W&P 25UL..breaker question
My wife and I recently purchased an 2010 W&P 25UL.
I made a mistake and left a light on inside the other day and ran the battery down. I plugged into shore power for about a day to recharge the battery. Battery is now charged but for some reason I am not getting 12VDC from the battery to the trailer. Everything works fine when plugged into shore power or when my truck is plugged into the trailer. I checked all the fuses in the fuse panel/converter panel and they are fine. I found some type of auto resetting 30Amp circuit breaker on the side of the frame next to the battery and I am only getting 4VDC on the trailer side of the breaker (12VDC on the battery side). I believe this breaker must be bad, but am not sure if I am doing something wrong as this is the first RV we have had.
This is the breaker I am talking about:
Amazon.com: Bussmann BP/CBC-30HB Type I 30 Amp Circuit Breaker Two 10-32 Threaded Studs: Automotive
I dont believe there is anything loading the circuit because all is fine when plugged into the truck or to shore power.
Any ideas?
grantopus is offline   Reply With Quote
Old 06-14-2014, 10:26 PM   #2
HarrynSally's Avatar
Try bypassing it
Sent from my SAMSUNG-SGH-I337 using Forest River Forums mobile app
HarrynSally is offline   Reply With Quote
Old 06-15-2014, 04:14 AM   #3
fonzie's Avatar
See if there is a resetting button on the side, otherwise by-pass it and replace as soon as possible.
Fonzie
Old 06-15-2014, 05:02 AM   #4
Is that small black plastic tab a reset? I thought that just kept the breaker in the "saddle" mount.
Old 06-15-2014, 05:05 AM   #5
fonzie's Avatar
That is the reset, push in.
Fonzie
Old 06-15-2014, 09:53 AM   #6
I replaced the breaker this morning and all is well now. I also replaced the ground from the battery. I guess I may have stressed the breaker when I ran the battery down and recharged it?!?!
Thanks for all the help.
breaker
