04-30-2012, 08:27 PM
Operating generator in truck bed
As I recently posted, I purchased a Dometic generator. Now my question is, can I operate the generator in the truck bed? My plan is to open the tailgate as much as possible (tailgate hits top of tongue jack), open tonneau cover and run generator while we are stopped but hooked up to tow vehicle. I even thought of dropping a ground wire from the generator to the ground and perhaps putting a small fan in bed to provide cooling. Of course I will be sure no flammables near.
The owners manual says not to operate generator in truck but they do not rovide a reason.
I am hoping you all tell me it's ok because it will be a real pain getting the generator out of the bed since I cannot open the tailgate but about 3/4 ways.
Thanks for your comments.
04-30-2012, 08:33 PM
I have done it before while traveling down the road before.
Ran a cord to Tt bulkhead plug .
05-01-2012, 10:43 AM
When dry camping my Boliy generator lives in the truck bed ALL the time, fortunately it just fits under the flip-up toneau cover so I can raise the last panel when the gennie is running. I have an extension 30A cord to use if needed. The main reason for leaving it in the truck bed is that I don't want the gennie to "grow legs" when we are away from the campsite.
...VTX-Al
05-01-2012, 10:47 AM
My generator lives in my truck bed on dry camping trips, but I can put my tailgate all of the way down. I make sure the exhaust is pointed away from everything
05-01-2012, 10:59 AM
My Yamaha 3000 lives in my truck bed pretty much 365/24/7 cause it is so heavy. I built a "home" for it in the bed. The exhaust side has metal foil and insulation to keep the heat off the waterproof Teflon coated Kevlar (friend in the business) I made the cover out if.
The reason it should not be run in the bed is it gets hot. You should also not run it "uncovered" in the rain or when wet.
The electronic inverter will be damaged if run wet.
The ground connection on the generator is not for connecting to the "dirt" ground; but to the camper's frame. This way your GFI's in the camper will be reliable when you power the camper with your genset.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-01-2012, 12:53 PM
So should I ground the generator to the frame or will the ground wire in the power cord do the same thing? When does the actual ground (dirt) come in?
Also, wow, I didn't know know you could put so much in the bed with a fifth wheel hitch. Nice.
05-01-2012, 01:37 PM
Yea, and its a short bed, too.
I don't believe "Dirt" ever comes into play with our campers when using a generator. They are "frame grounded." I have a gator clip on a long wire that I clip to the camper's frame when we boondock. That is all I have ever done.
Maybe one of our electricians can jump in here.
05-01-2012, 02:36 PM
Hmmmmm...... part owner in a plastic milk box company Lou ???? LOL
...VTX-Al
05-01-2012, 02:47 PM
Wanna Be Camper
Our Honda stays chained into the box of our truck anytime it comes with us as well. The exhaust is pointed up and out the side by design with the Honda when it is set in the bed sideways.
From my Honda owner manual.
GROUND TERMINAL GROUND TERMINAL Before using the ground terminal, consult a qualified electrician,electrical inspector or local agency having jurisdiction for local codes or ordinances that apply to the intended use of the generator.
The generator ground terminal is connected to the frame of the generator, the metal non-current-carrying parts of the generator, and the ground terminals of each receptacle.
John & Deb
2011 Flagstaff V-Lite 30WRLS
05-01-2012, 03:04 PM
...VTX-Al
Be amazed what you can find if you look.
I have to add that the "milk" crates work GREAT not only in the truck bed but in the basement storage area. Makes loading and unloading for other uses and getting the camper inspected; a snap compared to how I used to do it.
PS they are not stolen. "Fake" Milk Crates are available at VERY attractive prices. http://www.cateringsuppliesdepot.com...FYje4AodKTT4Nw
05-01-2012, 03:06 PM
GROUND TERMINAL
GROUND TERMINAL
Mine says the same thing. I figured tying the frames together is what it meant. I could certainly be wrong though...
05-01-2012, 05:21 PM
If I was still a member of the TrailManorOwners forums I would copy out an old post of mine. I am going to check with my electrical buddy and so I can remember what the exact answer is. Its all the NEC.
Foard County News & Sassy Schoolmarm
with Lady & Chloe, 2013 39 days, 2014 59 days
2017 GD Imagine 2800BH
'07 GMC Sierra 2500HD Diesel 4x4
Why I got into RVing & More Fun
05-01-2012, 05:35 PM
Yes I am a member of the milk crate club!
1 kindling
2 fire starting paper
3 coleman lanterns (2)
4 white gas and girl scout fluid
5 dog bowls and food
6 misc.
We also use empty ice cream buckets with lids
1 dog leashes /chains
2 misc tapes fuses and bulbs spare thisis and that's.
3 coozies
05-01-2012, 06:46 PM
some local codes require you to ground your generator, others consider it to be a "closed" system only requiring bonding your unit if you run power from it into somewhere that is already fed from another power source (bonding two systems together).
I'd put your genny in your truck, turn it on and enjoy. Provided you have a decent extension with a working ground, you will be fine.
05-01-2012, 08:08 PM
Thank you. Better safe than sorry, for sure.
05-01-2012, 09:48 PM
Marlk S.
A ground to "the ground" is not necessary and could pose a potential electrical problem. Plugging the trailer into the generator is just like connecting to he power pole at the RV park. The ground connection on the generator is the same as the ground on the plug on the generator, it should be the same on the power supplied by the RV park. The RV is never directly connected to earth ground due to rubber tires and the poor connection of any metal touching the ground - jacks, etc.
Just hook it up and run as you would in a RV park.
I think lowering the tailgate and opening the tonneau cover should be just fine. The generator needs a way to suck in air and a place to blow it out. If you bedroom is in front of your TT I would think about a fan to blow the exhaust away from the trailer.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
05-01-2012, 09:55 PM
my Avalanche has a 3-piece bed cover. i simply take one off and run the Honda inside, to make it quieterj and to provide ventilation.
never have fooled with a ground, don't feel it's necessary, based on Honda posts.
05-03-2012, 04:33 PM
Thanks for the advice. Working on getting all the details worked out before leaving in June of our 7 week Florida to South Dakota/Colorado/wherever sounds good to go trip. I know I will miss a lot of the things I need to know, but advice from forum members sure is helping.
