Old 06-10-2012, 03:55 PM   #1
chuckg58's Avatar
Outside shower Installation on my Work and Play 18LT
Looking for any helpful suggestions with outside shower install on my 2006 Work and Play 18LT....Photos welcomed....
I expect to finished project before end of this month. ...talk 2 me folks....
Thanx Chuck'
Chuck's 2006' Work and Play 18LT
Precious Cargo / 2005' Honda 1800N
chuckg58 is offline   Reply With Quote
Old 06-16-2012, 01:11 AM   #2
1l243's Avatar
I don't think it would be that hard. You should get a shower box like this one.
Exterior RV Showers on Sale - PPL Motor Homes
Looking at your floorplan I would put it on the outside of the bathroom vanity. It will give you access to water lines. I would use pex tubing just like what comes on your 18LT. You can get it at Home Depot.
1l243 is offline   Reply With Quote
Old 06-16-2012, 07:36 AM   #3
sherdep's Avatar
when you cut the hole for the box - I would make a template out of cardboard and make sure it is a tight fit around the box before cutting the camper.
a Dremel tool works great for making the hole - just use the reinforced discs if you go that route.
I would use Dicor Lap Sealant around the box to seal it to the camper
and like stated above - I would try to keep it in a area where it wouldnt be hard to run water lines to it so it makes the install smooth and easy
Here is an Install I did with adding a Locking Door to my fresh water tank - pictures and all so it gives you an idea of what I did to cut the hole and seal it - http://www.forestriverforums.com/for...6-a-11807.html
sherdep is offline   Reply With Quote
