Propane quick connect
I installed a TEE into the 1/2" high pressure gas plumbing under my 18LT. Would like to quick connect into this tee using a hose to a Coleman grill that uses screw on bottle gas. The grill has a low pressure regulator. I installed a ball shut off valve at the port intended for grill supply. My plan is to have the connection point just ahead of the entry step along the bottom of the coach. What make of fitting or kit will let me make this install...... thanks for any advice.
2006 18LT ...Winegard Traveller dish, Renogy 100W solar
2003 Dodge 3500 QC diesel 2WD, Dometic 310 Revolution toilet, KingJack HD local antenna, Dometic elite window awning, Fantastic vent fan.
