Old 12-12-2012, 11:22 PM   #11
lonestar007's Avatar
two "stands"
Originally Posted by coderider View Post
The Cherokee vengeance 306v has an option hat includes two "stands" that go underneath the top corners of the ramp door turning it into a patio. So the folks using the bottle jacks and 4x4 are using an approach similar to FR. I would opt for something like that too just for the support and to reduce stress on those chain tie points.
two "stands" - two thums up!
lonestar007 is offline   Reply With Quote
Old 12-13-2012, 12:17 AM   #12
1l243's Avatar
THIS IS NOT MY RIG but I like this guys setup. When I was researching this I found a lot of guys that had done the deck support mod for the same reason. I also like the Heartland Cyclone Deck setup. I want to add a deck screened room as well.
1l243 is offline   Reply With Quote
Old 12-13-2012, 04:35 PM   #13
Nice, I like it!
Tom Time is offline   Reply With Quote
Old 12-14-2012, 02:19 AM   #14
BTW... what about those two ropes holding the doggy?
Old 12-14-2012, 08:18 AM   #15
The Cook.
That is so he doesn't leave the grill...so the food doesn't burn.
Old 12-14-2012, 08:36 AM   #16
Len & Cheri is offline   Reply With Quote
Old 12-15-2012, 01:11 AM   #17
Wow! You have your dog cooking for you dinner!!!
The only thing my dog is capable - is snatch all my food!
Old 12-15-2012, 08:14 AM   #18
pjones1969's Avatar
I used the same concept on my Puma 27sbu, works great. It had 2x2 steel square tube for the door frame on the trailer side and aluminum frame on the ramp door, I used "bed bolts" and threaded the bolt in from the backside rather than using their jamnut, all SS hardware on the outside.
pjones1969 is offline   Reply With Quote
Old 12-15-2012, 05:23 PM   #19
pjones1969, Are keeping that cable permanently attached, or you tak it down every time?
Old 12-15-2012, 05:59 PM   #20
pjones1969's Avatar
I take it down every time, 4 chain links
