Old 02-02-2012, 01:58 AM   #1
1l243's Avatar
Roof Construction
Can someone tell me what the layers of the roof construction is for the 2011 Work and Play Toy Haulers. I watched a video of construction on Ebay but it only showed a thin plastic film and then the one piece aluminum sheet. Is there some plywood up there somewhere? If so how much... I have a 30 WR...
It's interesting video if you have not seen it..
1l243 is offline   Reply With Quote
Old 02-02-2012, 02:46 AM   #2
One-Piece Aluminum
After seeing the video you posted, I looked to see what I could find. Yes, it is one-piece aluminum. Scroll below for the features for the 5th wheels, travel trailers, etc. That shown below is from http://www.rvandboatdepot.com/ohiorvandboats/Forest-River-RV/Work-and-Play/Toy-Hauler-Fifth-Wheels.aspx (Dave Arbogast RV and Boat Depot).
Work and Play Features:
Standard Features (2010)
Travel Trailers
18 Ft. LT Travel Trailers
11' Cargo Area
Can be Towed by SUV
Double Well Stainless Steel Sink
Three Burner Cook Top
Six Gallon Fast Recovery Water Heater
30 Amp. Converter
Non-Skid Flooring in Cargo Area with Ramp
Two Windows in Cargo Area
Mini Blinds and Valances
Smooth Fiberglass Exterior
RV Door with Screen
Twin 30 lb. Propane Tanks
Transition Flap Between Ramp & Floor
One-Piece Aluminum Roof
3500 lb. Axles
26 x 36 Standing Shower with Curtain
Vinyl Interior Walls in Cargo Area
3 cubic foot refrigerator
95 inch interior width
Insulated ceiling
Full Steel 4-1/4" C-Channel Roof Trusses, 16" On Center
20 - 28 Ft. Travel Trailers
100 inch Interior Width
Ducted Air
Insulated Ceiling
6 Cubic Foot Refrigerator
Six Gallon Fast Recovery Water Heater DSI
50 Amp Converter
RV Door with Screen
5200 lb. Axles
Vinyl Interior Walls in Cargo Area (For Easy Cleanup)
Fifth Wheels/Gooseneck
8.5 Feet in the Upper Level Sleeping Area
Built in Headboard with Wardrobes
Vinyl Wall Covering
50 Amp. Converter
RV Door with Screen
6000/7000 lb. Axles (Depending on Model)
Twin Thirty lb. Propane Tanks
100 inch interior width
Ducted air
Insulated ceiling
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
campdohbrew is offline   Reply With Quote
Old 02-02-2012, 02:53 AM   #3
1l243's Avatar
What I would like to find out is what's under the one piece aluminum roof..
Old 02-02-2012, 08:30 AM   #4
Usually there 3/8 inch OSB (oblong strand board). I walk on mine, and many others, but I only weigh 130. Have been on campers with 2 others on the roof, repairing damage, etc. I am a tech, part time. A work and play may be solid plywood, sine the floor and walls are, at least they are on my 18 LT. I know that for sure.
If you really need to know, remove the inside trim piece for the vent, only 4 screws. You should be able to see the hole they cut, and the edge of the wood under the aluminum top roof.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 02-02-2012, 12:26 PM   #5
1l243's Avatar
I was thinking of that but then thought the vent holes could be reinforced because they are a vent holes? But I will do that and see what I see. Thanks...
Old 02-10-2012, 08:40 AM   #6
Roof
I will explain the roof construction.
Steel of wood rafters are the core of the roof. Steel in all FRP models, Wood in Ultra models up until July 2011, then they were also switched to Steel rafters.
Steel rafter, inside has ferrowing strips on each rafter, 1"x2" this allows for the mounting of the cieling panels.
The roof in insulated.
there is no plywood decking over the entire roof. There is an area of luan down the middle for support. There is a vent box installed for all vents and A/C this allows for support around the vent areas. a 1 piece aluminum roof is pulled out over and mounted in place with perimeter trim and screws. Forest River does not reccomend walking on the roof. If you need to be on the roof for some reason, use a section of 1/2" plywood to distribute your weight evenly.
Dcasteel is offline   Reply With Quote
Old 02-10-2012, 11:10 AM   #7
1l243's Avatar
Thanks for that information. I guess that is what the video shows. I was thinking that maybe they had just left a part of the construction out.
I have never walked on my roof because I just did not know. Now I do. I have to admit I am a little disapointed. I have and will continue to use the plywood for support. Thank You..
Old 02-10-2012, 11:34 AM   #8
TURBS's Avatar
Oriented strand board = osb
Old 02-10-2012, 12:15 PM   #9
1l243's Avatar
You would think but if you watch the video and hear what Dcasteel wrote, it's just a thin layer center strip of Luan which is a inexpenisve plywood usaully around 3/16" or less down the middle and the aluminum roof over the top..
