02-02-2012, 02:58 AM
Roof Construction
Can someone tell me what the layers of the roof construction is for the 2011 Work and Play Toy Haulers. I watched a video of construction on Ebay but it only showed a thin plastic film and then the one piece aluminum sheet. Is there some plywood up there somewhere? If so how much... I have a 30 WR...
It's interesting video if you have not seen it..
02-02-2012, 03:46 AM
One-Piece Aluminum
After seeing the video you posted, I looked to see what I could find. Yes, it is one-piece aluminum. Scroll below for the features for the 5th wheels, travel trailers, etc. That shown below is from http://www.rvandboatdepot.com/ohiorvandboats/Forest-River-RV/Work-and-Play/Toy-Hauler-Fifth-Wheels.aspx (Dave Arbogast RV and Boat Depot).
Work and Play Features:
Standard Features (2010)
Travel Trailers
18 Ft. LT Travel Trailers
· 11' Cargo Area
· Can be Towed by SUV
· Double Well Stainless Steel Sink
· Three Burner Cook Top
· Six Gallon Fast Recovery Water Heater
· 30 Amp. Converter
· Non-Skid Flooring in Cargo Area with Ramp
· Two Windows in Cargo Area
· Mini Blinds and Valances
· Smooth Fiberglass Exterior
· RV Door with Screen
· Twin 30 lb. Propane Tanks
· Transition Flap Between Ramp & Floor
· One-Piece Aluminum Roof
· 3500 lb. Axles
· 26 x 36 Standing Shower with Curtain
· Vinyl Interior Walls in Cargo Area
· 3 cubic foot refrigerator
· 95 inch interior width
· Insulated ceiling
· Full Steel 4-1/4" C-Channel Roof Trusses, 16" On Center
20 - 28 Ft. Travel Trailers
· 100 inch Interior Width
· Ducted Air
· Insulated Ceiling
· 6 Cubic Foot Refrigerator
· Six Gallon Fast Recovery Water Heater DSI
· 50 Amp Converter
· 5200 lb. Axles
· Vinyl Interior Walls in Cargo Area (For Easy Cleanup)
Fifth Wheels/Gooseneck
· 8.5 Feet in the Upper Level Sleeping Area
· Built in Headboard with Wardrobes
· Vinyl Wall Covering
· 50 Amp. Converter
· 6000/7000 lb. Axles (Depending on Model)
· Twin Thirty lb. Propane Tanks
· 100 inch interior width
· Ducted air
· Insulated ceiling
2012 Rockwood 8314BSS
2011 Chevy
Camping, Dutch Oven Cooking, and Homebrewing
02-02-2012, 03:53 AM
What I would like to find out is what's under the one piece aluminum roof..
02-02-2012, 09:30 AM
Usually there 3/8 inch OSB (oblong strand board). I walk on mine, and many others, but I only weigh 130. Have been on campers with 2 others on the roof, repairing damage, etc. I am a tech, part time. A work and play may be solid plywood, sine the floor and walls are, at least they are on my 18 LT. I know that for sure.
If you really need to know, remove the inside trim piece for the vent, only 4 screws. You should be able to see the hole they cut, and the edge of the wood under the aluminum top roof.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
02-02-2012, 01:26 PM
I was thinking of that but then thought the vent holes could be reinforced because they are a vent holes? But I will do that and see what I see. Thanks...
02-10-2012, 09:40 AM
Roof
I will explain the roof construction.
Steel of wood rafters are the core of the roof. Steel in all FRP models, Wood in Ultra models up until July 2011, then they were also switched to Steel rafters.
Steel rafter, inside has ferrowing strips on each rafter, 1"x2" this allows for the mounting of the cieling panels.
The roof in insulated.
there is no plywood decking over the entire roof. There is an area of luan down the middle for support. There is a vent box installed for all vents and A/C this allows for support around the vent areas. a 1 piece aluminum roof is pulled out over and mounted in place with perimeter trim and screws. Forest River does not reccomend walking on the roof. If you need to be on the roof for some reason, use a section of 1/2" plywood to distribute your weight evenly.
02-10-2012, 12:10 PM
Thanks for that information. I guess that is what the video shows. I was thinking that maybe they had just left a part of the construction out.
I have never walked on my roof because I just did not know. Now I do. I have to admit I am a little disapointed. I have and will continue to use the plywood for support. Thank You..
02-10-2012, 12:34 PM
Oriented strand board = osb
02-10-2012, 01:15 PM
You would think but if you watch the video and hear what Dcasteel wrote, it's just a thin layer center strip of Luan which is a inexpenisve plywood usaully around 3/16" or less down the middle and the aluminum roof over the top..
