Old 09-23-2014, 11:03 AM   #1
KD 1's Avatar
SCREWS????
Where can I get a bit for these Torx-like screws on this W&P?
I got some mods I want to do but I need to remove these screws.
KD 1 is offline   Reply With Quote
Old 09-23-2014, 11:05 AM   #2
TURBS's Avatar
Should be a number 2 square bit found at any hardware store.
Old 09-23-2014, 11:07 AM   #3
KD 1's Avatar
Nope, not that one. There are a bunch of Torx type on these. There are some of the ones you speak of too. I have it.
These look like a torx but my torx bits won't fit.
Old 09-23-2014, 11:13 AM   #4
Iwannacamp's Avatar
Any tool/hardware store has an assortment...usually $10-15 with "ALL" the bits you will ever need, unless they are like bigger than a 1/4" or so.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 09-23-2014, 11:16 AM   #5
KD 1's Avatar
Not having any luck there. May have to get one from the dealer. The last ones I removed with the drill the head off method...replaced with a more common screw/head.
Thanks for the help though
Old 09-23-2014, 11:17 AM   #6
Post a photo of the screw head and maybe we can help.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 09-23-2014, 11:23 AM   #7
Dazed & Confused
M&K Hoffman's Avatar
Could be some sort of anti-tamper screw. Would not see why, but it could be. Our local True Value sells a complete set of anti-tamper bits for around $20.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 09-23-2014, 11:31 AM   #8
KD 1's Avatar
I see part of the problem. These are 12 point torx, my bits are 6 pt. I never knew there was such.
Also in looking at my TH I find that there are at least 5 different screw heads.
( there is also the anti-tamper ones)
Plus bolts.
Old 09-23-2014, 11:37 AM   #9
KD1, the picture looks like an 8 pt, not 12 unless my eyes are playing tricks on me.
Old 09-23-2014, 11:38 AM   #10
Kaadk's Avatar
Plus bolts.
I only count 8 points in that photo. If it was 12, then the 6's should have had enough bite to be able to turn them.
It's strange to see them using a non-standard screw like that. My trailer's only been #2 robertson's, #2 Philips or staples.
The surest way to lose is to play Marco Polo with a ventriloquist.
Kaadk is online now   Reply With Quote
