Old 12-31-2013, 02:41 PM   #11
invertor
And I say spend the money and dont worry about having to turn stuff on and off that is a pain
not only that you are sure to forget and bang could damage unit or ac or whatever, you spent money on the rig now finish it the proper way!
if you have kids or wife like I do they run everything from TV to lap top to curlling irons, You will be happy you have the power !
Brett Rahn is offline   Reply With Quote
Old 01-03-2014, 01:25 PM   #12
BrianSF-GA's Avatar
I just realized something ... my toy hauler has a 30 amp box and main breaker. My understanding that is 3,600 watts max (120v X 30a). The Honda EU3000 is 25 amps rated maximum output and the Yamaha EF4500 is 37.5 amps rated maximum output. So I guess no matter what inverter I purchase, I will only be able to pull 30 amps (3,600 watts) through my fuse box.
Is my thinking correct here?
White 2016 Work & Play Ultra 25ULA, Cherry Wood, Pebble, Onboard Onan 5.5, Onboard Fuel Station, 50-Amp Service
Onyx Black 2015 Chevrolet Silverado 2500HD DCSB, 6.6 Duramax/Allison, LTZ/Z71 397bhp/765t
Shadow Black 2016 Ford Mustang GT Premium Convertible 435 bhp (Wife's Toy)
Merlot Sunglo 2011 Harley Davidson Street Glide FLHX, FM 107", PM Heathens 21"/17", Metzeler ME880's (200 Rear), 115rwhp/124rwt
BrianSF-GA is offline   Reply With Quote
Old 01-03-2014, 02:16 PM   #13
30 amps is all you need, your main breaker will trip when you go over. Two Honda or Yamaha ES2000 will but you right at 30 amps.
2014 Silverback 33RL
2013 F350 DRW 6.7
jimmac28 is offline   Reply With Quote
Old 01-03-2014, 02:38 PM   #14
BrianSF-GA's Avatar
... thanks. Just wanted to be sure I was thinking correctly.
Old 01-17-2014, 10:04 AM   #15
After all my investigation of what would be good for me, looking at wattage, sound, area/space they take up, and weight I purchased two of the EU200I Honda inverter/generators. One is a regular inverter and the other is the companion inverter. I purchased these brand new, with the connector, from a guy off of ebay. I save $200.00 extra by buying it offline (Hey, The guy had a good rating, I took the chance, I paid through PayPal, it paid off). The companion inverter has the 30 amp connection.
The reason for the Hondas is that on all of the reviews I found no one had any complaints, except don't store them with fuel in them and should be said for all equipment!
As I said, I was concerned about the weight. I have seen my friends with there large 4500's or 6500's generators that weight around 200 pounds and having a limited area to transport these (No offense to someone who have these! The weigh was a big concern for me) Each of the Hondas only weigh 47 pounds (dry weigh). I can lift one in each hand and I can move them around very easy. As I get older I don't want to be pulling, dragging or lifting a heavy generator. I can load them into the bed of my truck or on my WPT30 garage area without any help or problems.
Both units together give a combined 4000 watts peak, and 3600 watts full time. These units power my 15000 A/C unit and all my lights, TV's and radios that I need (But I must say that on my TH if I have the A/C running with lights, refrigerator, radios and TV's playing, I need to turn something off if you want to run a another high wattage items such as a 1200 watt hair dryer, toaster/oven, etc), but I'm good with that! During the months I don't need A/C, I only need one generator running which saves me on fuel and generator hours. To keep one unit from building up more hours then the other I rotate them. To use the regular generator I have the 30 amp adaptor.
Also If I need a generator for other then the TH I can carry one to the site and just plug in.
Well, there are pros and cons to everything but in the end you need to figure out what your needs are and buy what is best for you.
Good luck!!!
Tom Time is offline   Reply With Quote
Old 01-17-2014, 11:50 AM   #16
BrianSF-GA's Avatar
Good luck!!!
Very good response and I thank you for taking the time to write it. You make alot of good points that I have already been tossing around. I have made the decision that I do not want anything that will limit my usage below the 30 amps (3,600 watts) that my main breaker is capable of. So I have decided a minimum of 30 amps (3,600 watts) of continuous power is what I want.
According to the manufacturers' specs, the 4,000 watt maximum power of the companion EU2000's & EF2000's is limited to 30 minutes with a rated continuous power of 3,200 watts. That is slightly shy of my goal and there is added cost and setup of a long term fuel tank and companion cabling. There is also an option of using two EF2400's for 4,000 watts of continuous power, but their cost + the parallel kit is right at $3,000 plus the hassle of hooking up 2 generators ... the cost of the EF4500.
As of right now, I like the ease of rolling an EF4500 down the ramp door, plugging it up, pressing a button on an optional remote start and voila, power with the ability to pull the full 30 amps for 5-15 hours per tank full depending on load. The TH has the perfect size nook in a back corner for it. A few d-rings and she is strapped right in.
Old 01-18-2014, 01:03 PM   #17
EnduroRdr's Avatar
I have 2 of the Honda 2000i (regular and a companion) I love these things - if I don't run the a/c I just run one of them. I got the gas non-vented gas caps with gas tubing so I could run both from and aux 6 gallon gas tank (no worries bout running out of gas in the middle of the night).
I can run both generators for over 24 hours straight on this setup - tested after hurricane Katrina.
Actually if you google the gas caps non-vented and converted to adapt the hoses you can use any remote gas can - as the gas in the generator tank starts to empty it creates a vacuum and draws the gas from the external tank - you just have to have you other end of the tubing at the bottom of the aux tank. Works like a charm! No need to have aux tank higher than generator - it will suck the fuel up and over into the gen, (besides its safer to have the aux fuel lower than the gen in case of leaks.
Note these can also be converted to run on propane with a kit - I did that with my little 2600 yamaha, and have thought about it with the Hondas too but so far having the extra gas can has worked out fine.
This is my setup for the Yamaha 2600 which can run on either gasoline, natural gas, or as shown here running on propane. these are cool conversion kits.
Note the 2600 is just slightly too small for the trailer use - this is our hurricane mode setup - I stick a 12000 b.t.u. window unit in the living room of our house and all is well but it is too weak for the camper use so I purchased the hondas for camping in the TH.
Anyway - food for thought - but really if you have a 30 amp feed to your trailer - "that is max use" and rarely do you need to have continued 30 amps. (with 15K a/c running mine draws 23 amps measured at the plug. Micro off when measured) Nobody I have talked with that uses these combo 2000i units has ever out run the capacity for their 30 amp trailer - actually several folks I know get along with the 3000 units and never have an issue - I say this because I hate to see you buy more generator than you may really need. And like suggested above if you only need one (like when not using a/c) the fuel savings is great - they sip fuel! One unit usually runs 6-8 hours on the internal "one gallon" tank. Yes you have to connect an additional cable to run 2, and they are not electric start, but to me the compact portability makes it really nice using the 2 smaller units and my totla investment was under $2000 included parallel cable when purchased on-line. My 2 cents.
2011 Work & Play 27UL and 2006 Dodge Ram 2500 5.9 Cummins.
EnduroRdr is offline   Reply With Quote
Old 01-18-2014, 01:47 PM   #18
Another thing you might want to do is to get a hard start solinoid for your A/C. It will keep your generator from kicking down if you are close to the max amps when starting it. I use one of these for my Toyhauler with no problems. Best price I found was Sears. It has a battery start and pull start. I have used mine for 2 years with no problems.
Top B is offline   Reply With Quote
Old 01-18-2014, 03:13 PM   #19
hrlyguy2's Avatar
I have a generac 6500 like 8k watt start up.More likely enough to power my rig
but loud.Seen guys make boxes to quiet it down.
ANY one done this before ?
Not trying to hijack a thread figure talking about generators
2007.5 Chevy 3500Ltz cc lb Duramax
2010 Sandpiper 345 RET (SOLD)
hrlyguy2 is offline   Reply With Quote
Old 01-18-2014, 04:11 PM   #20
I made a box for mine so I could run it in the back of my pickup and vent the heat from the exhaust out the top of the box. My generator is pretty quiet, but it made it quieter (can barely hear it running). My box connects to the exhaust end of my generator, but I'm guessing you want yours to enclose your generator. I used plywood with metal shielding (facing in to protect from heat damage to the wood), L-brackets, fireproof insulation, and a home heating vent cover for the exhaust. You would probably need another one for the intake side if your going to enclose it.
generator, inverter, power
