Old 09-30-2014, 04:06 PM   #11
Witch Doctor's Avatar
Originally Posted by gljurczyk View Post
This is not a 4 season package and this is from the salesman on the tape.
Well here is the foam answer, all they spray are the holding tanks, This is not a 4 season trailer, If they sprayed the underbelly you couldn't ever make a repair. See attached from the salesman. It's hard to read but his email is "the spray foam is around the tanks" So FR still doesn't make a true 4 season trailer unless you live in Florida. As Eland pointed out.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-07-2014, 10:54 PM   #12
Work and Play will never be a 4 season trailer using it's present construction technique. The FRP walls are 3/4" plywood with a fibreglass layer on the outside, and 1/8" paneling for looks on the inside. The R value of the wall is less than R-1 according to the Plywood Manufacturers Association website. They would have to add at least 2" of some sort of insulation material to the wall, defeating the entire reason for making an FRP trailer.
The roof has 4" of fibreglass insulation, about an R-9 value. None of the plumbing is isolated completely from freezing temps on outside runs.
I live full time in this 34FK. I just move it to central TX in the winter. Problem solved.
beyerjf is offline   Reply With Quote
Old 10-09-2014, 08:06 PM   #13
1l243's Avatar
Went in to a RV Dealer today that sells the Work and Play and they had four units on the lot. All of them had spray foam underbelly. The entire underbelly is spray foamed. I give Forest River a A for effort but it is Darn ugly. Spaying the foam even with the frame rails and the trimming excess or even using black spray foam would be a much nicer looking installation. I also read that to complete the package for the Work and Play they use thin insulation before putting the inside wall paper on and dual pane windows... They would not let me pull back the wall paper but I don't think the wall insulation amounts to much but more than just the FRP siding by it's self.
1l243 is offline   Reply With Quote
Old 10-09-2014, 08:17 PM   #14
heavynlori's Avatar
Looks like a sure fire mouse buffet .....
heavynlori is offline   Reply With Quote
Old 10-09-2014, 08:22 PM   #15
RSchleder's Avatar
My 2015 Wildcat MAXX has an enclosed undercarriage and the pipe openings are foamed. If you cut away any of the undercarriage material you'll find it has a insulation layer bonded to the underlay. The tanks are "heated" by a furnace run which does dump some amount of hot air into the enclosed undercarriage area when the furnace is running. Not exactly a 4 season solution to cold weather, but better than nothing!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 10-09-2014, 08:37 PM   #16
1l243's Avatar
More care or the method should be improved. You can see in picture one that a big chunk of foam is getting ready to fall off of the holding tank..
Old 10-10-2014, 01:18 AM   #17
Look's like one big mess, an a nightmare to work on.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-10-2014, 07:47 AM   #18
There are many engineering changes that would have to be executed to make a W&P a 4 season trailer. These appear to be band aid approaches to the issue. Can you imagine the reaction of a prospective customer at the Hershey RV show who has every major toyhauler on display looking at that mess underneath, and going across the parking lot to a Keystone product and seeing how they make a trailer a 4 season trailer? And how about some performance numbers? What is the R-value of this new "insulation" under the wall paper on the wall?
Thanks, leave it without their insulation package and I can deal with it better than that.
Old 10-10-2014, 02:38 PM   #19
I have a 2014 Work & Play 275 ULSBS that I ordered last year. I took delivery in October of 2013.
The spray foam under the trailer is starting to shrink, pulling away from the cross beams.
What really upsets me is when you order this option, the ceiling is also foamed. So if the foam is shrinking underneath, then it is shrinking in the ceiling leaving part of my roof un-insulated.
Geofish is offline   Reply With Quote
Old 11-03-2014, 10:55 AM   #20
rjtimmer's Avatar
damn. i hope that's not what they do. not even close to what i was told by the FR dealer rep during our phone conversations. he said they use foam insulation, with a cover/barrier to enclose the belly. i asked about plumbing and wiring, i was told all was serviceable.....
well, i guess i will see Friday when I'm at the factory.
rjtimmer is offline   Reply With Quote
underbelly
