Old 06-15-2014, 08:36 PM   #1
Biker's Avatar
tie down suggestions
So the toy hauler is here.
Want to haul the golfcart and the Harley.
Anyone have tie down suggestions? Add tie downs? Mount a bike bracket?
Don't want to make a trip hazard.
Biker is offline   Reply With Quote
Old 06-17-2014, 03:42 AM   #2
1l243's Avatar
I use ETrac. Three sections bolted to the floor left, cener and right. I use a Condor Chock for the bike. Shown here in a old post of tweaks and mods of mine.
Mods and Tweaks for 30WR Work and Play #1
1l243 is offline   Reply With Quote
Old 06-17-2014, 05:37 AM   #3
E Track above correct answer! Youroo!!
Old 06-17-2014, 07:55 AM   #4
prof_fate's Avatar
Bikes/quads are fairly easy - get as many of these as you need (4 per quad, 2 will wok on a motorcycle) and pull down against the suspension. 6 ft. Cam Buckle Tie Downs, Set of Two
In my cargo trailer I too have etrac (harbor freight has some, grainger other bits). They sell eTrac rings Search results for: 'etrac ring' that you can place or remove as needed. I put track on teh walls as my trailerhas big rings in the floor for quads. Used self tapping fasteners and attached it to the 'studs' (frame?).
they also sell 'brackets' that clip into etrack that fit a 2x4 - handy to make a shelf or brace across as a cargo hold, or what I did was put on 1' long 2x4 and made a shelf that can be removed.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 06-17-2014, 10:46 AM   #5
1l243's Avatar
The Condor does come with a mountiung bracket. When the Chock is removed the bracket remains. It's about 1.5x8x.05.... It will stick up from the surface of the floor. We use our garage as a extended livingroom when the bike is out we put a carpet down cut out where the condor brackets are. Makes it less of a trip hazard..
I prefer ratchet type tie downs vs the buckle type. I actually use the ratchet tie downs that come when the new Harleys are shipped to the dealer. Harley dealers usually have a ton of these laying around and give them away for free a very cheap. I like them because they don't have hooks. You will also want to get some soft ties. These are lengths of nyon strap with loops at each end.
If you bought a Work and Play you won't be able to put Etrac on the wall really no need for it anyway. When intalling Etrack I used 1/4" cariage bolts. Bolts closer together where likely to have strap locations like the ends and then maybe ever 12 inches or so in other areas. A 8 foot section of Etrac in my trailer could have 20 or more cariage bolts per strip..
Old 06-17-2014, 06:04 PM   #6
2014 XLR 27HFS
MaxxTow Adjustable, Self-Locking Wheel Chock - 15" to 22" Wheels - 1,800 lbs MaxxTow Wheel Chocks MT70271
Two toy haulers over the last 10 years with 10,000+ miles dragging my Harley Ultra-Classic around. I have one of the above chocks and love it. Drive the bike on and step off. The chock holds it in place by itself. Then I slip fork brackets on similar to the link below (mine are made out of really tough plastic, not metal). Two straps to the D-rings and that puppy doesn't move an inch.
Google Image Result for http://motorcyclepartsoutlet.net/wp-content/uploads/2013/02/Headlight-bracketblack-300x235.png
Dave & Audrey
dave961 is offline   Reply With Quote
Old 06-17-2014, 06:16 PM   #7
Lynkage's Avatar
I like these because they do not put hooks on certain parts of your bike/toy!!
The strap wraps around a bar and then attaches itself to a ring on the strap.
Keeper 8 ft. x 1-1/4 in. x 1,000 lbs. Motorcycle/ATV Ratchets (2-Pack)-05741 at The Home Depot
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 06-27-2014, 08:36 PM   #8
hauling kawasaki mule and heritage softail in 34.5 FK
What we did to make it fit...put the chock for the motorcycle in the door way between cargo and living room...that way we can pull the kawasaki all the way up to the wall and tie it down...in fact, still room for the bed to come down enough to sleep if we have too!...pm me at Ebendana@yahoo.com and I can send you a pic fully loaded
EBendana is offline   Reply With Quote
