Old 02-17-2019, 01:17 PM   #1
Marine3038's Avatar
Towing 30wqb w Tundra?
Anyone towing a 30wqb (or similar) w a Tundra? Looking to see how it performs
Marine3038 is offline   Reply With Quote
Old 02-17-2019, 01:22 PM   #2
I have zero experience with tundras but 3 times a day I read threads about towing with one and they all seem to steer towards payload very quickly. My brief google search shows that to be a very heavy work and play unit? pushing the limits of any 1/2 ton truck. (coming from a non weight police guy.)
Kimber45 is offline   Reply With Quote
Old 02-17-2019, 01:23 PM   #3
Scoundrel
HangDiver's Avatar
38 feet long and a GVWR of 13,000lbs? This is a joke, right?
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 02-17-2019, 01:25 PM   #4
BigH's Avatar
Originally Posted by Marine3038 View Post
Anyone towing a 30wqb (or similar) w a Tundra? ...
I hope not...
17 Chevy 2500 DC Long box Gasser Z71 4.10
18 Vengeance 28V
BigH is offline   Reply With Quote
Old 02-17-2019, 01:40 PM   #5
Citrus County, Fl.
GL1800Rider's Avatar
If it can tow the space shuttle it can tow that
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 02-17-2019, 02:11 PM   #6
Retired JSO's Avatar
I started with a 1500 z71 Chevy when we bought our W&P, 25 WB. Stayed in 4th gear almost always. Trailer seemed to control the truck. The W&Pís have a heavy frame but ours was it as heavy as what you are looking at.
Retired JSO is offline   Reply With Quote
Old 02-18-2019, 02:24 PM   #7
Marine3038's Avatar
Damn I didnít realize they weighed 13k. Thought I read they were 9k (dry weight).
Old 02-18-2019, 02:32 PM   #8
Ejs4029's Avatar
Here are the 2019 Spec's.....Geez I pity the poor Tundra owner who thinks its up to the task
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 02-18-2019, 02:36 PM   #9
dry weight and gross weight are two different things. 9k dry is pushing even a max to 1/2 ton. look at tongue weight and your payload and I think you will see a tundra is not up to the task. safely any ways.
Old 02-18-2019, 02:49 PM   #10
Prime Member
That's too much trailer for my Chevy 3/4 ton. Definitely too much for a Tundra.
Temporarily Camper-Less
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 02-18-2019, 04:21 PM   #11
dcheatwood's Avatar
You can "pull" it all day long and through the night. The problem is the weight on the truck. I towed 2 fivers for 9 years with no power or stopping issues. But I had to use airbags to keep it from bottoming out on bumps and from sagging all the time.
However, the bags don't give more payload/cargo. They just keep it level.
2018 Forester 3011 DS
Old 02-18-2019, 04:23 PM   #12
HONDAMAN174's Avatar
As a tundra owner- I would not pull that unit.
Just glad to get away
Old 02-18-2019, 05:49 PM   #13
Scoundrel
HangDiver's Avatar
Dry weight generally refers to the trailer as it came off the assembly line; no water in the tanks, empty waste tanks, no propane, nothing added on by the dealer. Using Gross Vehicle Weight gives you a more realistic number for a travel trailer thats loaded up and ready to go camping. Using 13% of the GVW will give you an approximate hitch weight on the back of your truck.
Old 03-05-2019, 07:26 PM   #14
The dry weight of a trailer is a joke . My 30WR lists for just under 8k . On the scale , no water , food , cargo , just a few dishes , 2 propane tanks and too batteries is just over 10k . I figure any rv trailer is @least 1000 pounds more that its listed for .
Big Red and 30WR is offline   Reply With Quote
Old 03-05-2019, 08:08 PM   #15
Tundra 2014
I have a 2014 Tundra, earlier comment about limited cargo is very accurate. I try to pack light w/ total length 31'9"-2715 Flagstaff V-Lite. Total weight is 7100 w/ 40 gallons of fluids. No, I do not normally tow this way, but if we stay somewhere boon docking, I will for a short distance. We have added everything possible to the truck to make this work. OK on flat ground, towed 3.5 K between TX and Florida. Not enough truck for the camper you are talking about, if you have Tundra maxi cab, payload is 1400 total. The hitch weigh of your trailer is going to be 1100 lb +. loaded. Then add driver, passenger, tool box gas, firewood, propane and battery weight. The other weakness in this truck is brakes. I switched to TRD brake shoes and that helped, at 62K I have had front rotors turned, 3 frt. set of pads. My brother-in-law has a year newer and at 60k same story and only pulls light trailer w/ small tractor, very little. My previous trailer was 4K, no problem. These are great trucks, on my second one, but over 6K trailer weight and any hills, not enough truck. I get about 9 MPG-27 gallon tank.
Tundra 2014 is offline   Reply With Quote
Old 03-05-2019, 08:16 PM   #16
Tundra 2014
Tundra
I agree, Dry weigh is before any options like 2 nd. air, battery ,full propane tanks electric down riggers, ETC. I had mine weighted by each wheel 960 over dry weight sticker. Toyota actually backed off max tow weights in newer models.
Old 03-25-2019, 06:20 PM   #17
Wrong wwightWell I have a 30' WP. My trailer loaded with water tanks full, tounge weight is right at 1690 ish.
I used a 2017 F250 CCSB with a 6.7.
It pushed that truck around like a rag doll.
With proper wieght distribution setup.
Got of getting pulled around by 18 wheelers on the highway.
Problem solved 2019 F350 CCLB DRW.
Its great pulling it now.
FYI I get my tounge weight with a hitch scale and weight trailer on cat cert scale!
Txfoster is offline   Reply With Quote
towing, tundra
