Old 06-26-2013, 06:35 AM   #1
the3gibsons's Avatar
TV mount for bedroom in 30WRS
Been searching the threads with no luck on an answer. I have a 2012 30WRS and want to put TV in the front bedroom. The plugs are there but no mount or clue where to put a mount. I'm thinking after viewing the Forest River production video a few times that there are "studs" in that interior wall.
Suggestions? Pictures of how you may have solved this?
Thanks - Chip
Retired USMC - Semper Fi
2012 Work & Play 30WRS
2013 RAM 2500 Laramie CCSB 4x4
the3gibsons is offline   Reply With Quote
Old 06-26-2013, 07:10 AM   #2
Dave_Monica's Avatar
There's usually an area where they've put a backing board between the studs to mount the TV bracket and the area is labeled. If the location of the backing board is not obvious, try contacting the manufacturer using the number in the brochure and ask for the location. You may need to provide your camper's VIN.
Dave
