Old 06-16-2012, 01:21 AM   #1
1l243's Avatar
Upgrade TV Antenna
Has anyone upgraded their saucer type antenna with a crank up Batwing?
Winegard Sensar IV DTV/HDTV Antenna - Winegard RVW-395 - Over-the-Air Antennas - Camping World
1l243 is offline   Reply With Quote
Old 06-16-2012, 06:11 AM   #2
Herk7769's Avatar
If you already have a Sensar antenna you just need to add the "Wingman" to get the same effect.
RV-Wing Wingman HDTV Upgrade Add-on Sensar RV antenna on eBay!
HAM CALLSIGN - KC3FFW
Old 06-16-2012, 07:41 AM   #3
lindy's Avatar
We got rid of our "Bat Wing" antenna for the "JACK" antenna by King Control. The Jack antenna was 100% better then the bat wing. Tried the Wingman upgrade to the bat wing and saw no noticable difference.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 06-16-2012, 10:16 AM   #4
COMer
I would also recommend the Jack. We added a Wingman to our Batwing and it did make things much better for the upper channels, but it hit the fridge vent when it was down so we switched to the Jack since it is smaller and didn't hit anything. It does work better than the Wingman and Batwing. And it is less directional. Handy if you are in an area where channels are available from a variety of directions.
jbirrell is offline   Reply With Quote
Old 06-16-2012, 11:24 AM   #5
1l243's Avatar
Most of the Work and Play TH that I have seen have the Omnidirectional Amazon.com: Winegard RS1500 Omnidirectional TV/FM Antenna: Automotivelike I do. I am not impressed with it. Will look into the Jack antenna...
Old 06-16-2012, 11:33 AM   #6
COMer
You can add the Jack to the crank up equipment that is left from the Bat Wing when you remove it. That means you can update for about $50.
Old 06-16-2012, 11:40 AM   #7
1l243's Avatar
The Omnidirectional is not crank up it does not move. I was wondering if the roof structure of the Work and Play will support a crank up style TV antenna without any modification. The roof consist of thin outside sheet aluminum covering some very thin Luan. I would think the roof would have to be structured for a crank up type antenna?
Old 06-16-2012, 12:22 PM   #8
ken0042's Avatar
Being in Canada I have different pricing available to me. The Wingman upgrade costs around $70, and the entire Sensar IV head will cost me around $100. I know in the States the Wingman is closer to $30 and the Sensar IV is around $75; so I can see why it may make sense to do the upgrade.
So here is my question- if you were looking at $70 for the Wingman and $100 for the entire Sensar IV; which one would you choose? I keep looking at the Sensar IV and thinking with it being all integrated it might work a little better. Or am I wasting that last $30?
As for going with a Jack; I did the upgrade package and was not pleased with the end results. (My Results)
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 06-16-2012, 12:31 PM   #9
bob213's Avatar
The Surveyors are coming with that same antenna. I believe the AC unit blocks most of the signals. The antenna is usaually worthless. I think the stationary Jack would be the easiest replacement, not sure about the Jack that rotates.
bob213 is offline   Reply With Quote
Old 06-16-2012, 12:46 PM   #10
Herk7769's Avatar
In my opinion you would be wasting your 30 Canadian Dollars. The snap on Wingman just adds the non-powered elements that are the same as the Sensar 4's molded in ones.
Not sure why buying in canadian would be double. The exchange rate is pretty close to parity now.
$ 1 USD = $ 1.0213 CD
antenna, led pad
