Old 09-07-2015, 06:57 PM   #1
Water Heater Bypass?
On our new 2016 38RLSW we can not find the water heater bypass for winterizing storage. It has an Atwood 10gal DSI unit. Any ideas?
sstuner is offline   Reply With Quote
Old 09-08-2015, 07:02 AM   #2
JCMINIS's Avatar
Mine is right beside the tank. Have to take a panel off inside the unit with 4 phillips head screws. I can snap a pic when I get home from work if you want.
2016, 3500 DRW,CCLB,CTD,G56,3.73
Work and play 40RLS,
PROUD OF MY USAF and ARMY SONS !
JCMINIS is offline   Reply With Quote
Old 09-08-2015, 07:10 AM   #3
Georgia Frog Rally 2018
aceinspp's Avatar
Find the location of the water heater then remove any panel there to get to the heater. Bypass lines right at heater. Should be 3 knobs to turn. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 09-09-2015, 05:29 AM   #4
rjtimmer's Avatar
FYI, you can buy cabinet doors with hardware from the W&P factory. Or you can go to Bontragers Surplus in White Pigeon Michigan for the hard ware....replace those screw panels with actual cabinet doors, you will gain a lot more stowage.
we did all three panels on along the bottom of the kitchen counter, as well as the bottom of the bathroom vanity.
"Workamping Professional"
2015 WPF40RLS
2012 Ram 3500 DRW G56
1997 TJ-ish....
rjtimmer is offline   Reply With Quote
Old 09-10-2015, 06:25 PM   #5
I see three panels in the kitchen that are screwed in. I didn't have time to investigate further but will this weekend. Thanks to all
Old 09-10-2015, 06:38 PM   #6
Ford Idaho's Avatar
I vote for panel "B"
It will be low, looking at the tank from outside try to imagine where it would be inside.
Old 09-10-2015, 06:55 PM   #7
Flybob's Avatar
It is the panel behind where the water heater is located ( use outside access door as your guide).
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-12-2015, 06:49 PM   #8
Took panel off in kitchen area that was retained by 4 screws and here is a photo of the Atwood 10 gal water heater with bypass set to summer mode. Sorry photo upside down.
bypass, heater, water, water heater
