Old 01-24-2016, 10:57 AM   #1
Water heater bypass
Just bought a 2016 38fks work and play. It was delivered yesterday. I looked at the owners manual and it mentions the water heater bypass. All it says is located by the water heater but I can't find it. Anyone know where it is? The water system currently has antifreeze in it from the factory.
Bond is offline   Reply With Quote
Old 01-24-2016, 11:10 AM   #2
Ford Idaho's Avatar
Look at the water heater from outside, now go inside and imagine where the back of the water heater would be.
Under a bench seat or the mattress?
Under the fridge or kitchen sink behind a panel?
In a closet or cabinet?
Old 01-24-2016, 08:27 PM   #3
Found it. Removed drawer and someone with small hands can reach it. Looks like the 12 yr old has a new job lol
Old 01-24-2016, 08:39 PM   #4
Flybob's Avatar
There should be three valves, If the WH is winterized ( Bypassed) two will be perpendicular to the lines they are in and one will be parallel to the line it is on. To put back in service in the spring ( after you rinse out antifreeze and sterilize ) turn all three to the opposite position as they are now, ( two parallel to the lines and center one perpendicular to line)
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-18-2017, 10:03 PM   #5
Cajun Style's Avatar
ID:	148671Click image for larger version
Cajun Style is offline   Reply With Quote
bypass, heater, water, water heater
