Old 06-08-2013, 06:11 AM   #1
HarrynSally's Avatar
Thumbs down Welding
Does any one know a little about welding on TT I need to do some welding and some one told me that it could messup my bearings and some one told me that as long as i put the ground wire right next to were I'm welding i'll be alright.
HarrynSally is offline   Reply With Quote
Old 06-08-2013, 06:44 AM   #2
Witch Doctor's Avatar
Just take the bearings out. If you are worried. Also if your trailer is new I wouldn't weld anything on it. It would VOID your warranty.
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-08-2013, 07:39 AM   #3
As long as you connect the ground to the trailer frame, you should be ok, but if the trailer is still on warranty, any welding on the frame will void said warranty.
Old 06-08-2013, 07:52 AM   #4
Cajun Style's Avatar
No, No warranty
Cajun Style is offline   Reply With Quote
Old 06-08-2013, 07:54 AM   #5
TURBS's Avatar
What are you welding ?
Old 06-08-2013, 07:54 AM   #6
The work is on the tongue and I'm changing the steps.
Old 06-08-2013, 07:57 AM   #7
fmc
fmc's Avatar
I've had 40 plus years in the welding & fabricating industry and I can assure you that welding will NOT ruin your bearings!!!!!!!!!!
fmc is offline   Reply With Quote
Old 06-08-2013, 07:58 AM   #8
I just cleaned and repacked the bearings now I have to set the brakes.
Old 06-08-2013, 07:59 AM   #9
Thanks I just wanted assurance .
Old 06-08-2013, 08:01 AM   #10
Send a message via MSN to Tiggerdad
There is a theory that when welding on steel with bearings, an arc could create a spot on a bearing that would ruin it. It was thought that this arc would occur on any bearing between the ground and the welding point. In all the years I worked in the maintenance field, I never saw that happen, not even in babbitt bearings. Good welding practice would be to attach the ground as close to the welding point as possible.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
