Old 06-18-2012, 11:29 AM   #11
1l243's Avatar
I just went on Walmart web site to check that out. I have never even seen one of those. $14.95 is better thant $99.99
Walmart.com: Road Power 50/30-Amp RV Power Adapter: Computers
James seems that there is always something that goes wrong on the first trip. Did the water leak cause damage? How did you find it?
1l243 is offline   Reply With Quote
Old 06-18-2012, 08:48 PM   #12
1l243's Avatar
Originally Posted by jamesroadking View Post
Well back from the first shake down trip with the 30WRS Work and Play. water pump under the bath room sink sprang a leak, some little inline filter or anti back flow plastic thing with a screw on cap needed alittle little more elbow greese. Will make the access panels removable for alot more added storage area in the bathroom.
The generator worked fine, but I am concerned about the heat from the exhaust damaging the gel coat. I might try lifting the generator to the F250's bed for the next trip, it will fit under the tonneau cover like it just fits onto the generator rack if I keep the wheel kit removed.
1/243, I have those adpters for the power cords (left overs from when I had a class A coach). I actually use the 30 amp to 115 adpter to an heavy extension cord for plugging in at home. The A/C, frig, TV's, etc. all work fine using the 115 volt plug in adpter, but I might just pick up an 30 amp RV extension cord that way I can plug into the 30 amp RV generators outlet.
James got any pics of your new rig, I would like to see it..
