Old 08-25-2013, 08:43 AM   #1
jdb
Where's the Hot Water Bypass?
2007 Work and Play 20BR.
Looking for the hot water tank bypass setup. Can someone tell me where I'd find it?
Thanks.
J.D.
jdb is offline   Reply With Quote
Old 08-25-2013, 08:46 AM   #2
onetonford's Avatar
Usually Right behind the water heater mine was behind a fake wall in the cabinet.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 08-25-2013, 08:49 AM   #3
wmtire's Avatar
Thanks.
J.D.
It should be at the back side of your hot water heater. Since I don't have your particular model trailer, the easiest way is to go outside and find the access panel to your hot water heater. Once you know where the hot water heater is at, then you can back inside and look where you can access it from inside. You may find a panel you have to unscrew, or a hinged cabinet door that also must be unscrewed to gain access.
Outside panel will be similar to this:
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-25-2013, 08:54 AM   #4
PHS79's Avatar
Like onetonford said they are usually very close to the water heater. Most of the time the WH and by are not in the most user friendly spot to get to and may sometimes hidden. On our TT it was under the bed in the "master bedroom", I almost have to crawl into the compartment under the bed to get to it. On our old TT it was under the sofa, I could see it and I could reach it, but I just couldn't do both at they same time where it was placed. Good luck!!
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 08-25-2013, 08:58 AM   #5
wmtire's Avatar
Old 08-25-2013, 09:30 AM   #6
TURBS's Avatar
This
Old 08-25-2013, 09:36 PM   #7
jdb
Thanks guys.......
Next time I'm at the storage lot, the hunt is on.
I'll let you know where I find it....
J.D.
Old 09-23-2013, 02:20 PM   #8
I have a 30FLA and it was under the bed...
Haedtime01 is offline   Reply With Quote
hot water, water
