Old 09-20-2013, 11:37 AM   #1
Work and Play WPT28DB
It's a 2008 trailer and the previous owner removed the second fresh water tank - the front one. I reinstalled the tank and plumbed it the way I thought it should be done. I don't seem to be drawing water out of the front tank. Has anyone got a diagram or picture of the plumbing setup? If I'm going to haul the extra weight, I'd like to be able to use it.
scout3351 is offline   Reply With Quote
Old 09-20-2013, 09:13 PM   #2
1l243's Avatar
I did not know they had a second fresh water tank? And why would he remove it?
1l243 is offline   Reply With Quote
Old 09-20-2013, 10:14 PM   #3
It has 2 30ish gallon water tanks, one under each seat at the table. They took the tank out for more storage room. He made an aluminum cover for the wall fill opening and cut and plugged the water line going to the second tank. They gave us the tank when we bought the trailer.
On another note - if the picture works - does anyone know where I can pick up a twin for this water fill locking cover that PO installed. I've looked at a lot of them but can't find one with the rubber seal around it.
Old 09-20-2013, 10:59 PM   #4
1l243's Avatar
Did not know they put water tanks under the dinette. I wonder why they did not put the tank under the frame like the other models? Did not see the pic..
Old 10-10-2013, 08:00 AM   #5
BBQ'er
D Casten's Avatar
I dont have a picture with me but my front tank is just plumbed into the back tank. So when you fill one they slowly balance out.
D Casten is offline   Reply With Quote
Old 10-11-2013, 07:55 AM   #6
D Casten: Thanks for the reply. Does yours have separate fill openings for each tank? So, if I'm understanding your description correctly, as the water level goes down the tanks should level out, so the first tank would not completely empty out. I will have to check the vent in the second tank as mine doesn't seem to be leveling out and seems to suck air when the first tank empties.
On another note, anyone know what the trailer I.D. number/letter combination denotes? WPT 28DB?
WorkPlayTrailer? Length? DB - no guess!
Old 10-11-2013, 10:32 AM   #7
BBQ'er
D Casten's Avatar
Correct, two seperate fill tubes which are also the vents to each tank.
I'll try to get a photo for you over the noon hour.
Old 10-15-2013, 08:29 AM   #8
BBQ'er
D Casten's Avatar
Here you go scout, pretty simple after you see it.
First pic is the front tank fill tube and vent, there is one for each tank.
Second is the output/drain from the front tank and where the line runs to the back.
Third picture is by the back tank showing the splice (T) conecting the tanks together and into the plumbing lines.
ID:	41126   Click image for larger version
ID:	41127   Click image for larger version
I never saw or heard of a man being shot while cleaning the house.
Old 10-15-2013, 11:25 AM   #9
that looks like the way I plumbed it up but I will go out and check after lunch. I really appreciate you taking the time and trouble to help me out.
Bill
Old 10-15-2013, 07:19 PM   #10
It looks like I have it plumbed the same as yours so thats not the problem. The vent hose on the front tank was kinked a little but I don't think it was enough to cause a problem. I will keep an eye on it. Thanks again for all your help.
work and play
