Old 05-17-2015, 08:15 AM   #1
07 tahoe and 2007 21ss roo
Hey guys. Had some miscommunication with owner I bought from and the WDH was not included. I found a guy that has a equalizer 90-00-1200 which from what I read is a 4 point 12,000 lbs hitch
Is this too much for the 21ss?
wraenking is offline   Reply With Quote
Old 05-18-2015, 08:00 AM   #2
Hicks43's Avatar
It may be but put it this way it can be adjusted. Down and you will never need a new hitch. As campers get bigger
Hicks43 is offline   Reply With Quote
Old 05-18-2015, 08:02 AM   #3
Hicks43's Avatar
Btw mines a 1,000lb e2 on a 21ss 3/4 ton suburban don't need it just wanted the sway control.
Old 05-18-2015, 08:21 AM   #4
wicked1's Avatar
I am running a Camco EZ-Lift 1,00/10/000 had it for my 2012 Shasta with Tongue Weight at 900# I needed it but switched to a Roo with a TW of 570#'s I am using it but adjusted it to my F150 and Roo, works well and I have more towing room now. That setup you should be good but most important make sure it is setup correctly, there are a ton of videos so search on YouTube
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 05-18-2015, 08:27 AM   #5
Great. Thanks for the info guys
Old 05-18-2015, 09:11 AM   #6
The WDH should work fine. The only draw back may be that it will stiffen your ride/tow experience.
whallon1 is offline   Reply With Quote
roo
