Old 04-13-2014, 11:59 PM   #11
Kaadk's Avatar
All depends what you're plugging into at home. Is it a plug on a 15 amp breaker, a 20 amp breaker or a 30 amp breaker? Is there anything else on the circuit or is it dedicated?
In my instance, I plug into into the 15 amp circuit in my garage which also has my garage fridge, garage freezer, central vac, the powerwasher and whatever corded tool I need to use (like the table saw, chop saw, etc...) In my case, I wouldn't dare try to run the AC. (Ok, I did dare once just after getting the trailer last year, you can read about that fubar in my welcome thread.)
But, if I were to instead run the extension across the front of the house to the plug by the front door, that's on a dedicated 15 amp circuit and I'd probably be ok running the AC as long as I didn't try to use the microwave and converter or something at the same time.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 04-14-2014, 11:52 AM   #12
kfree1711's Avatar
All,
I know this is going to be a silly question / comment. I am in the process of purchasing a 2015 23IKSS. For some reason, I thought the shore power plug was a 200 / 30 amp. However, after reading this and checking the data...it appears that it is a 110v / 30 amp. I have an electrician coming to my house on Thursday to install a proper plug etc so I can plug my Roo in (when it is parked in my driveway) and want to make sure I have the proper plug / circuit installed. Thanks!
kfree1711 is offline   Reply With Quote
Old 04-14-2014, 11:57 AM   #13
wmtire's Avatar
Originally Posted by kfree1711 View Post
All,
It is a 120 volt 30 amp outlet. You can print out the pdf file from this link and hand it to the electrician to make sure he wires it correctly. We hear horror stories all the time where a professional electrician (unfamiliar with RV's) wired it for 240 volts.
http://www.forestriverforums.com/for...let-27223.html
2011 Flagstaff 831 RLBSS
Ive lost my scapegoat.
Old 04-14-2014, 12:01 PM   #14
kfree1711's Avatar
Thanks for the quick reply!
-Kelly
2015 Rockwood Roo 23IKSS
2009 Ford F150 Platinum
Nights Camped - 21
Camped Every weekend in July :=)
110v
