03-29-2014, 08:10 PM
110v pass through
Hey all,
I'm camping at Brown County right now. Pretty cold so we have 2 heaters running and using the furnace as a backup. To run 2 heaters I have an extension cord running from the power post through the access door behind my sofa.
I was wondering if anyone has put in a 110v pass through so you wouldn't have to let in some cold air thru an access door. I was searching on my phone and saw this.
150BBIW.RV - Marinco - Actuant Electrical - 15A 125V Rv Inlet White W/Park Power Packaging
A sealed one would probably be better but I haven't seen one yet.
Any opinions?
Greg
Sent from my SCH-I535 using Forest River Forums mobile app
'18 Ford F250 Lariat Super Crew
'22 Rockwood 2608BS
Previous '17 Grand Design Imagine 2800BH, '13 Rockwood Roo 21SS
03-29-2014, 08:32 PM
For now just put some duct tape around the opening to keep the cold air out. Remove it when closing up camp.
Bob & Rose, Greenfield, IN
2014 Flagstaff Micro Lite 23FB
Ford F150 ECO Boost 3.5L V6
3.73 Electronic Lock
Max Trailer Tow Package, 600# Equlizer 4
03-29-2014, 08:39 PM
Painters tape would work and less mess to cleanup.
03-29-2014, 09:48 PM
I'm not worried about it for this trip. I'm thinking for the future.
'22 Rockwood 2608BS
03-29-2014, 10:24 PM
Why do you need the extra cord? Are all your 15amp on one breaker? If you were to add an outlet using the AC breaker you would be able to run both heaters.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
03-30-2014, 06:45 AM
I have not checked our new camper, but the old one only had 14 guage wire. I would not run 2 heaters on that internal wire.
2013 F-250 CrewCab 6.7 PowerStroke 4X4
2017 Silverback 33RK
03-31-2014, 04:28 PM
Greg:
I added a receptacle and circuit so that we could run two 1500 watt electric space heaters. Here is the link to my mod.
http://www.forestriverforums.com/for...cle-51192.html
Brad
2009 Chevy Silverado/2500/6.0/3.73/CC
2016 Keystone Outback 250URS
2013 Rockwood Roo 233s (SOLD)
https://instagram.com/pineforestcamper#
03-31-2014, 04:36 PM
I took the plug off and drilled a hole the size of the wire and put the plug back on the other side of the wall. Pull the wire through the wall, plug stuff in. When done, pull inside and coil up behind chair or whatever.
04-01-2014, 06:54 AM
Originally Posted by grege
Hey all,
Any opinions?
Greg
When camping in the cool weather, I simply run an extension cord through the end window of the bunk to the post and tuck it under the edge of the mattress and on to the micro-furnace or heater. It works fine.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
04-01-2014, 07:44 AM
What I do is run my extension cord at the bottom of the slide rubber seal at floor level it works for me. Then you get the use of the 15 amp breaker at the pole. Hardly see any light at all coming through, If I do then I just put a towel to plug it. Some old man showed me that and had the nerve to say "that's how you do it rookie" Boy you just get to meet all kinds of people camping, the best part of it.
Coachmen M/H
Concord
2018 / 300 DSC
04-01-2014, 07:52 AM
You are letting in a little cold air at your main power cord port. Take the inside access panel off to the main power cord storage area and snake a heavy duty extension cord through the outside port beside the main power cord. You can mount can possibly mount a plug and face plate on your access panel, depending on how it is configured. store the extension cord out of the way of the main cord when not in use so they will not get tangled up.
Brother Les
