Old 11-07-2008, 11:24 AM   #11
CampeRooo
rthrbelsewhere's Avatar
I think if i were to mount this, I would drill a couple of holes on the bottom of the box and through a metal plate of some kind that would lay flat on the bottom, inside the box. Then run flat headed bolts through it and around the frame, through another plate on the bottom of the frame so that it grabs and hangs on. A pinch mount sort of thing, that way it can be removed if needed and also you dont risk weakening the tongue or a rail of the tongue by drilling holes in it. Might be easy enough to just load it in the front box....did you get a full slide through box in the front with your model?
Joe
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
rthrbelsewhere is offline   Reply With Quote
Old 11-11-2008, 03:55 PM   #12
No on the slide thru, Just returned from the maiden voyage. Well we ran outta gas the last night there and the temps were 31 degrees, thank the almighty for the heated mattress, I have a nice electric tower heater but it was tucked away in the garage at home, but we put together some ideas for future trips. I guess with the cold temps and the hot water heater, you can go through two tanks of gas quick. I also need to invest in some plastic levelers to run the tires up on, as the first shower ran water down the spigot wall and onto the floor because we were a little off from side to side. All in all it was a great trip and loads of fun.
NJLOAD is offline   Reply With Quote
Old 01-19-2009, 09:37 AM   #13
STATIC's Avatar
Congrats on the new trailer. I've had mine for a couple of years now, I am so glad that I bought a roo, best trailer around.
STATIC is offline   Reply With Quote
roo
